Re: Solar Heater, Brand, Cost and Hookup
Nothing wrong. I assumed it was a spring check to control the pressure going into the solar dome. What I do see is that with the 3-way set to allow flow to both the dome inlet and outlet that the pressure on both sides of the dome would be equal and the flow would be from filter to SWG to pool just bypassing the (pressurized) solar dome. I may be missing something.
