Re: Solar Heater, Brand, Cost and Hookup
BigDave
I'm sorry, yes the bypass valve was set there but that was just to take pictures.
Otherwise it set between 1 & 2 which allows half feed to solar heater and full feed to tee, is this correct, after thinking about it and speaking to you it doesn't seem right.
Here is a link to the manual.
http://www.poolmaster.com/wp-content..._10-4-2012.pdf
Please advise if I should change my connections?
Eddie
Summer Escapes 14' Pro-Series 4047 gallons, Intex 12 inch sand pump, Intex SWCG, Intex 2500 GPH Filter Pump, surrounded by Vinyl Works Fence using a Taylor K-2006C and Taylor K-1766, Sungrabber 4 x 12 feet Solar Collector, Hayward Aqua Solar GL-235, 12 mil Clear Solar Blanket
