Results 1 to 10 of 11
Thread: Taking over care of parents pool
    Jul 2014
    Massachusetts
    Default Taking over care of parents pool
    I'm glad I found this forum as I'm taking over the care of my parents pool since they are no longer able to keep it up. I went there yesterday and found the pool walls covered in green algae. There is also re algae everywhere (skimmers, bottom, sides). I know red algae is actually bacteria so I checked the bromine canister and of course it was empty. The pool is a kidney shaped gunite circa 1986, bromine, 36000 gallons with a DE filter. When I went looking for their test kit I found it dusty in the basement, apparently they have been relying on the local pool supply chain. I ordered a Taylor K2106 Bromine test kit. I will try to get the additional dimension data etc and fill out the form when I have a chance. A couple initial questions:
    1. I spent several hours scrubbing the sides and got off a good amount of the green algae, there is still some on the lower sides/bottom of the deep end and there is still red algae all over the bottom and skimmers. Should I start adding poly-quat algicide now or wait until I've brushed and vacuumed several times.
    2. My mother swears that you can only use an oxygen shock in the bromine pool. Is this true or did someone give her misinformation?
    Default Re: Taking over care of parents pool
    Since this is a bromine pool, I have asked PoolDoc to advise you. He is a lot more familiar with bromine pools than the rest of us.
    Welcome to the Pool Forum!
    Some years ago, some very effective bromine salesmen, presumably from Great Lakes Bio (bromine company of the era) were able to pull the wool over the eyes of a number of code authorities and pool stores in New England. The effects of their sales efforts are still being seen, lingering in some New York codes and in cases like yours.
    Compared to chlorine, bromine is overpriced and under-performing even for indoor pools. For outdoor pools, where it cannot be stabilized against photolysis by solar UV, it's MASSIVELY more expensive. I'd recommending switching to chlorine.
    If you don't want to do so, that's fine, but we don't support bromine use. I'm one of the few here who knows anything about it, and trying to support it becomes a distraction.
    Unfortunately, in cases like yours, switching requires a total drain and refill -- INCLUDING a washdown, partial refill, and flush of pipes and filter. The problem is, if even a little bromide (used bromine) + hydantoin (the chemical 'binder' in solid forms of bromine) linger, you will continue to have a 'bromine' pool, even if you USE chlorine!
    The reason is, chlorine is a stronger oxidizer than bromine, and oxidizes bromides (used bromine) BACK to active bromine -- but the chlorine is destroyed (reduced to chloride) in the process.
    A couple of other issues:
    1. You don't need a bromine kit: the ONLY difference between a chlorine kit and a bromine kit is the numbers: for a given color, the bromine numbers will be twice (2.25, to be exact) the chlorine numbers.
    2. Oxygen shock (non-chlorine shock, potassium monopersulfate) is an EXPENSIVE, inefficient way to oxidize bromides back to bromine. Just using chlorine, including 8% plain household bleach is a much cheaper, more efficient way to accomplish the same thing.
    Recommendation #1: Drain, rinse, refill and begin using chlorine. (Pressure wash any algae, but be careful not to strip paint or weak plaster.)
    BE CAREFUL: if the pool is not elevated significantly above the ground water (swamp?) I saw on Google Maps, just north of the house, when processing your registration, DO NOT DRAIN THE POOL. Even concrete pools can float out of very wet ground.
    Recommendation #2: If you want to think about it for awhile, just use bleach, dichlor or whatever form of chlorine is most cheaply available to you to raise bromine levels high enough to eradicate the algae. (ANY form of chlorine will simply react with the bromide reservoir to form fresh bromine). Add chlorine LATE in the day, so the bromine formed can 'work' all night, before being destroyed by sunlight the next day.
    If the pool has been operated a number of years using solid bromine, but without being drained and refilled, it may take VERY large doses of chlorine to form high enough levels of bromine to be effective. A large hydantoin residual greatly weakens the effects of the bromine present.
    Let us know if you decide to convert to chlorine, so we can guide you.
    Jul 2014
    Massachusetts
    Thanks for the fast reply, I have always suspected that the whole bromine is better thing was a lot of hot air because I've never really noticed a difference between swimming in the bromine pool or in chlorine ones with the exception of a couple commercial ones that I suspect were being run with higher chlorine levels.
    The pool is actually on the side of a hill so it sits well above (20 feet or so I would guess) the wetlands (Miles River, "river" being a bit generous a term perhaps) so I don't think the water table would be an issue.
    I have a couple follow-up questions:
    1. So just to be sure I understand, I can use the K2006C kit FAS-DPD test or an OTO based test and just multiply whatever drop/color based result I get by 2.25 to get the Bromine ppm?
    2. When I questioned my parents about why the switched to the oxygen shock the answer I got was that they thought it was safer and when they had used chlorine shock in the past it turned the water brown. I read the answer to the safety part of the question on your site already but is there anything that might be in the pool that could react with the chlorine to turn the water brown or cause brown staining? Is it possible that they are confused and something else they added turned the water brown?
    3. I'm slowly making my way through reading you site as time allows so my apologies if this next question is answered there. If I start using bleach or some other chlorine to shock how much should I be using per dose? Also, is there any type of chlorine that I should NOT use to shock the bromine pool because it has something else in it?
    4. The pool has not been drained since a new tile and plaster patching job was done somewhere in the area of 1997-2000 so I assume it may well have the high hydantoin levels and associated problems?
    5. I would love to convert the pool to chlorine but do to water use restrictions, the cost, and the time of year (the pool is unheated so there is only about a month or so of use time left) it won't happen this year. That leads to the next issue of cost and a perhaps bigger problem plaster condition. I didn't mention it before but the plaster is starting to come off the pool walls in a significant amount. This seems to be occurring a few inches below the tile line and progressing downwards. It's actually flaking off in significant size pieces ( I've seen a few that were 2-3" in diameter) and there is clearly more plaster beginning to separate away. Given this, I'm guessing the pool needs to be replastered sooner rather than later. I assume that replastering the pool would eliminate the need for the washdown and just require flushing the pipes? I also assume that given the plaster condition it would not be worth it to go through the chlorine conversion process before replastering?
    6. Assuming they decide to replaster and convert to chlorine rather than fill in the pool, any recommendation on going with a SWCG system versus a traditional chlorine system?
    I appreciated the great information and assistance you provide. I'm sure I will have even more questions assuming they decide to go ahead with the repair and conversion next year. Thanks for all your help.
    Chris
    Quote Originally Posted by cconte View Post
    Yes.
    Brown, as in brownish-red? Probably bromine gas in partial solution. If the brown disappeared after mixing, then that's what it was . . . and it probably indicates an extremely high bromide residual. Short term, you can avoid that by chlorinating via the skimmer.
    Long term, it indicates that it will be really important to drain, rinse and flush (pipes, filter, pump) and then re-drain.
    Calcium hypochlorite will add calcium; dichlor and trichlor will add stabilizer, but that will not affect your pool at present. Bleach will add a bit of salt, but because it's instantly in solution, you're more likely to see the bromine gas formation.
    Very likely.
    All you say seems to me to likely be correct.
    If you are having to care for the pool, and are not living there, an SWCG would make things easier. But they don't actually save money. They just provide a very reliable continuous chlorine feed system.
    Keep in mind that the salt levels required may not be compatible with some of your pool hardware. But that could be replaced when you re-plaster.
    Jul 2013
    Northern Illinois
    Chris: I keep seeing you online. Do you have any questions or are you good?
