Results 1 to 10 of 12
Thread: confusing readings on 4 year old SWCG
    Default Re: confusing readings on 4 year old SWCG
    Thanks, Kelemvor.
    May 2012
    Winston-Salem NC
    Thanks for the input, and all the advice!
    Just got back from getting the salt levels read - a whopping 4500 ppm. Yikes. I will definitely get one of the check at home kits.
    Also talked to the local pool repair guy who does Hayward warranty work. He think it sounds like the cell, but that a nice acid bath might fix it, so that is in progress right now. If that doesn't fix it, I'll replace the cell. I'm going to stick with the Hayward stuff and not go aftermarket - too scared of crummy warranties!
    If the salt is too high for the generator to work obviously I'll dump-and-replace water, but assuming the washed, or new, cell claims to be generating when everything is back together, is there any long term harm in having salt that high? The generator itself says it wants up to 3400 ppm, but yesterday (when it thought the level was too low) it claimed to be generating, as if the crazy high level wasn't preventing it from working.
    Thanks again for all the help!
    Alison
    16'x40' kidney / "nautilus" 25K gal IG vinyl pool; SWCG; Hayward ProSeries high rate sand filter; Pentair SuperFlo 1HP pump; hrs; Taylor K-2006C; utility water; summer: homemade solar disks; winter: mesh; ; PF:4.8
    Jul 2014
    Oklahoma
    I should have been more specific. I changed the cell and the control unit at the same time. In that case it doesn't matter what brand you choose. The Pentair was recommended to me, plus it had a three year warranty compared to replacing the cell only and getting a one year warranty from Aqua Pure. On top of that it was cheaper to replace the entire system with the Pentair than to only replace the Aqua Pure cell.
    Regards
    25k gal 22 x 34 concrete free-form (oval) IG pool; city water; SWCG, Jandy CV460 cartridge, Jandy SHPF pump, 12hr, bubbler. PF=4.8
    Pentair units work.
    But I should note that the experiences reported here -- included my own, having installed 6 of the things -- suggest that they have a shorter life expectancy than other units. Again it's nothing absolute, but it seems the Hayward / Aqua-Rite and the AutoPilot units are preferable.
    May 2012
    Winston-Salem NC
    I bit the bullet and changed the cell and all is functioning again. I also got the salt down to 3800ppm (according to new unit) so I'm letting it go at that.
    I had the local Hayward guy come do the work, partly to get it done as quickly as possible (going out of town, of course - my limited experience suggests that pools always stop working right before you are about to leave them for a few days...) and partly to have experience on hand if it turned out NOT to be the cell. He said that AquaRite has changed its panel configuration in the last couple of years to address the not-infrequent premature burn-out that has plagued the earlier models, so the newer panels are much more likely to live for longer. (I asked about this because I have had to replace a burnt out capacitor on my panel already, and it was only two when it burnt out! Capacitors croaking was the issue with the premature burn-out, which Hayward has now fixed.)
    And I have ordered the salt-checking kit!
    Thanks again for all the help and wisdom.
    Alison
    Largo, Florida
    Did you ever try acid washing the cell? When you said you cleaned the cell originally I assumed you meant with acid. Acid washing is something that you're going to have to periodically do. There's even instructions in the aqua rite manual on exactly how to do it.
    If you didn't try the acid wash, and haven't disposed of the cell then keep it as a backup.
    May 2012
    Winston-Salem NC
    Yes, I did the acid wash but it didn't change anything. I then got the new unit installed and have had no trouble with it since.
