Results 11 to 12 of 12
Thread: confusing readings on 4 year old SWCG
    Largo, Florida
    Default Re: confusing readings on 4 year old SWCG
    Did you ever try acid washing the cell? When you said you cleaned the cell originally I assumed you meant with acid. Acid washing is something that you're going to have to periodically do. There's even instructions in the aqua rite manual on exactly how to do it.
    If you didn't try the acid wash, and haven't disposed of the cell then keep it as a backup.
    May 2012
    Winston-Salem NC
    Yes, I did the acid wash but it didn't change anything. I then got the new unit installed and have had no trouble with it since.
    16'x40' kidney / "nautilus" 25K gal IG vinyl pool; SWCG; Hayward ProSeries high rate sand filter; Pentair SuperFlo 1HP pump; hrs; Taylor K-2006C; utility water; summer: homemade solar disks; winter: mesh; ; PF:4.8
  1. So confusing about chemistry!!!!
    By reboot530 in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-06-2012, 01:18 PM
  2. Recent problems with erratic readings from my 3 year old Pool Pilot Digital DIG-220
    By ronbar in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-16-2011, 05:03 PM
  3. New SWCG and strange FC/CC readings
    By Furbabyvet in forum Dealing with Algae & Slime
    Last Post: 05-24-2011, 11:19 AM
  4. High Chlorine readings - how do they impact other readings
    By Charlie in forum DPD-FAS based testing
    Last Post: 02-06-2009, 10:41 PM
  5. Confusing CYA readings
    By mshumack in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-26-2006, 04:04 PM
