Re: I think I have Black Algae
I have a standard 5 liquid drop based test kit....but I just went to pinch-a-penny and had them do the test since I assumed you needed some of the other tests.
Here are the numbers:
Total Chlorine = 5.0 ppm
Free Chlorine = 5.00 ppm
Combined Chlorine = 0.0 ppm
pH = 8.0
Acid Demand = 4
Total Alkalinity = 160 ppm
Calcium Hardness = 370 ppm
Stabilizer = 90 ppm
Salt = 3,500 ppm
The crystal stuff I had used was called Spot Out (a pinch a penny product). It was made up of Trichloro-s- Triazinetrone.
When I switched to the Aqua Chem shock. It was made up of:
Sodium dichloro-s-triazinetrione 63.05%
Copper (metallic / derivde from copper citrate) 0.26%
Available Chlorine 39%
BTW, I did get a little of the black/green stuff from the tile grout and smeared it on white paper. It was interesting because it did not smear too good. Basically crumbled but left a thin dark green smear on the paper.
