Results 1 to 9 of 9
Thread: 2006 reads 20
    May 2013
    Concord,ca
    Default 2006 reads 20
    Had to do some cleaning up due to a pool leak. Leak is fixed but stabilizer is on 20 maybe because 2006 wont go lower. I guess add more stabilizer and wait? What else is there I can do? My cl is 4.0. I have the stabilizer is that the right direction to go? Had a lot of algae so I had to scrub its gone now. I used liquid 12.5
    13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
    I only trust the k-2006 titration is better for me
    Default Re: 2006 reads 20
    When is the last time you have either added CYA directly or used trichlor or dichlor?
    May 2013
    Concord,ca
    added 1.5 lbs cya 5 days ago I do have tricolor tabs though but I haven't used since bbb. I could use the floater for a week and check it and when it comes back I could stop and go back to bbb. BTW thanks for getting back
    Am I remembering correctly that you will soon be leaving for a 2 or 3 week vacation? If that is right, you might want to use some trichlor while you are gone.
    May 2013
    Concord,ca
    leaving in 2 months preparing now, don't want to be caught off guard, But ok I will add the triclor for now thank you Watermom
    Oh. I thought you were leaving sooner. IF you do decide to use the tabs now, keep an eye on your pH. It is very acidic and will drive your pH down.
    A couple other options instead of using the trichlor now:
    1) Go ahead and add a little bit more stabilizer directly to get to around 45-50 and then use the tabs while you are on vacation. If you do this, you will want to leave a little wiggle room for the tabs to add some CYA while you are using them.
    2) If you have any, use some dichlor now which will add CYA and chlorine. Again, if you do this, leave some room for the CYA to increase a little if you plan to use the tabs while you are gone.
    Choices, choices.
    One other thing, if you do use trichlor while you are gone, you'll want to raise your pH up to the upper 7s so that if it does drop while the tabs are being used, and it will, it won't go below 7.0.
  1. Pentair Minimax will not fire on and reads "HI"
    By gradynlisa in forum Pool Equipment & Operations
    Last Post: 04-18-2014, 05:38 PM
  2. Using the K-2006
    By Manslick in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-07-2011, 11:31 AM
  3. Filter pressure reads zero
    By Jellybeanck in forum Pool Equipment & Operations
    Last Post: 06-20-2011, 12:33 AM
  4. ph test phenol red reads 7.2 then jumps to 7.5 !
    By maxhiller in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-11-2007, 12:42 PM
  5. CH test reads 0?
    By cygnusecks in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-09-2006, 04:44 AM
