Re: Smallish pool Huge question
Rig 'em up in parallel or series? Series won't do much as the first filter will catch almost everything that will be caught. The better filter cartridges from the SSR page will help with water clarity but the pump will still only move so much water.
Polyquat might help but won't let you go a week. If you're going away for a weekend put in as much bleach as you'd use if you were home. Covering the pool with an opaque cover will help a lot.
