Results 1 to 8 of 8
Thread: Cloudy Pool Water (First Post)
    Default Re: Cloudy Pool Water (First Post)
    Are you sure that you don't have a K2006 kit instead of a K2005? How are you testing chlorine readings past 5ppm with a K2005 kit?
    A K2005 kit cannot measure high chlorine levels. In fact, it will bleach out at high levels and appear that there is no chlorine sometimes when the chlorine might actually be very high. If that really is what you have, you can order an add on kit -- Taylor K1515, and it will give the test that your kit is missing that the K2006 that we recommend has. It allows you to read much higher chlorine levels. You probably won't be able to find it locally, but can get it through this link:> http://pool9.net/tk/
    Continue to keep your chlorine high. And, run the pump 24/7 while you are working to clear the pool.
    (Until your registration is completed, you won't be able to follow links or see the rest of the forum while you are logged in. So, copy that link and paste it into a browser window after you first log out.)
    May 2014
    USA
    Just checked my test kit and it is a Taylor K-2005. Purchased it online. According to instructions, you can get an approximate high chlorine level by filling with pool water to only the 1.8 ml mark and then filling to the 9 mm with distilled water before adding the two sets of drops. You then multiply your reading by five. You can measure up to 25 PPM (approximate) that way. I'll look into the Taylor K1515 add-on kit. I removed all the leaves and have continued to keep the chlorine high and will keep the filter running. The water is clearing again. Also, what do I have to do to complete my registration? I thought I filled everything out but maybe I missed something. I've never used a forum before other than just reading other peoples posts. Thanks again for your help.
    You've done all that you need to do. Now, Ben has to do his part. It takes time for him to verify all the information (or lack there of) that people give when they join. Sometimes, it gets kind of stacked up in this 'Getting Started' section but he'll get it done. It will be worth the wait, I promise you that!
    In the meantime, feel free to ask questions here if you need to. Also, do a lot of reading here on the forum and also over on our sister website www.poolsolutions.com. Lots of great info there as well.
    Again, welcome and glad you found us.
    (Until your registration is completed, you'll have to log out first to be able to see the rest of the forum.)
    May 2014
    USA
    OK, thanks for letting me know. I'll be patient. I have been reading posts for a couple of years and have always found answers to issues I was having but this time I couldn't figure out what was going on. This forum is a great source of information. Thanks again for your help.
    You are welcome!
  1. First post - salt water kiddie pool?
    By nwbickham in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-10-2014, 12:41 AM
  2. Post Isaac Situation (cloudy)
    By jilted in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-11-2013, 06:35 PM
  3. Scale in a salt water pool (first post)
    By allanlaw in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-01-2011, 02:45 PM
  4. Cloudy Pool Water - Could use some help
    By bcooper27 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-05-2010, 03:43 PM
  5. New pool cloudy water???
    By lilmank in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-07-2006, 08:59 AM
