Thankfully my pool is not green and we got a major storm that filled it up last night. I did dose it w/bleach and stirred it around while I fished out storm debris.
The 1.5 hp came with the kit so that is why we had it. I just trusted them to give us the right stuff:/ I hope the pics help give you the right info. Saving $ on electric and the pump would be fabulous! let me know if you still think it would work.
Idk if this is relevant but the skimmer/feeder is an AquaGenie. I know this is not standard so it may play a part in the functioning of the pool. http://www.hydrapools.com/products/aqua-genie
The filter is a top mount SS24T so i would have to stick to a top mount because of the way the equipment shed is set up (see pic) you can also see some of the sand the leaked out in that pic too
Thank you sooo much for your time and knowledge!
Paige
In ground, outdoor, vinyl liner, 22,000 gallons w/Aqua Genie skimmer installed in 2008, 1 HP Hayward 2-speed Super Pump and Hayward pro series high rate S244T both installed 2016
