Results 1 to 10 of 16
Thread: How long till chlorine level will drop
    rdefino is offline Registered+ Thread Analyst rdefino 0
    Jun 2013
    Haverhill, MA
    Default How long till chlorine level will drop
    I had to shock my AG 18x34 yesterday, it started to get a little cloudy. Definitely made a difference.
    FC is at 14ppm, how long will it take to drop to a swim-able level if there is no stabilizer in there. It's also has a solar cover on it.
    Also, what is a swim-able level for FC?
    ph7.2
    alk80
    thanks for help
    Oval 18x34 14400 Above Ground Dough Boy, DE Pentair
    Jun 2014
    Default Re: How long till chlorine level will drop
    You shocked yesterday. Have you checked your fc today? Because, without stabilizer / cya it might already be gone.
    19.5k gal, 16x32 vinyl liner, sand filter, 1hp single speed pump, K-2006 test kit. PF=6
    Jun 2013
    Haverhill, MA
    yes I did. It's 14ppm. We had no sun today, rain and heavy clouds.
    Jun 2014
    Ok, but my point was meant to say...
    Your larger issue is not having cya. You'll loose fc very rapidly without it. How fast is based on many factors (algae, sun, etc). The only way to control the rate of loss is with cya.
    What was your reading just after you shocked? That reading compared with now with will give you a good indication of the rate of decline for your situation.
    Jun 2013
    Haverhill, MA
    It was 15ppm yesterday after shocking. I just want to be able to use the pool come Saturday.
    Jun 2014
    Checked your weather forecast...Haverhill will be sunny and hot next couple days. Your fc losses will be higher. Saturday is looking good.
    Jun 2013
    Haverhill, MA
    Cool. Will the solar cover slowdown the FC loss? Also, what is an acceptable FC level to swim in?
    Jun 2014
    A solar cover shouldn't make much difference.
    Check the Best Guess Chlorine Chart
    http://www.poolsolutions.com/gd/best...ine-chart.html
    You can swim even at shock level with no problems. Just don't want to wear your best swimsuits that might fade.
    Jul 2013
    Northern Illinois
    How is your pool doing?
  1. Chlorine drop ?
    By FNC1962 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-08-2012, 09:41 AM
  2. Chlorine level doesn't want to drop
    By bhc33 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-25-2011, 11:57 AM
  3. How much should chlorine level ppm drop?
    By smallpooldad in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-20-2008, 06:58 PM
  4. Chlorine level drop quickly
    By jdw-tx in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-27-2007, 09:00 AM
  5. Chlorine level drop
    By circlenranch in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-02-2006, 11:24 AM
