yes I did. It's 14ppm. We had no sun today, rain and heavy clouds.
Oval 18x34 14400 Above Ground Dough Boy, DE Pentair
Ok, but my point was meant to say...
Your larger issue is not having cya. You'll loose fc very rapidly without it. How fast is based on many factors (algae, sun, etc). The only way to control the rate of loss is with cya.
What was your reading just after you shocked? That reading compared with now with will give you a good indication of the rate of decline for your situation.
19.5k gal, 16x32 vinyl liner, sand filter, 1hp single speed pump, K-2006 test kit. PF=6
It was 15ppm yesterday after shocking. I just want to be able to use the pool come Saturday.
Checked your weather forecast...Haverhill will be sunny and hot next couple days. Your fc losses will be higher. Saturday is looking good.
Cool. Will the solar cover slowdown the FC loss? Also, what is an acceptable FC level to swim in?
A solar cover shouldn't make much difference.
Check the Best Guess Chlorine Chart
http://www.poolsolutions.com/gd/best...ine-chart.html
You can swim even at shock level with no problems. Just don't want to wear your best swimsuits that might fade.
