Results 1 to 5 of 5
Thread: Eyes burn
    Bosch232 is offline Registered+ Thread Analyst Bosch232 0
    Aug 2012
    Nebraska
    Default Eyes burn
    pH is 7.8
    Chlorine is low at 2.5 ppm (I added chlorine).
    Vinyl lined AG pool.
    What else should I test for?
    16x32 Oval AG vinyl pool; Media Master sand filter; 1.5 hp 1 speed pump; 10 hrs; Rural utility water; Taylor K-2006
    Jul 2010
    Largo, Florida
    Default Re: Eyes burn
    Combined Chlorine, Total Alkalinity, CYA, Calcium Hardness
    Actually, I am not aware of calcium hardness affecting or causing burning eyes, even if it is too high. Calcium is useless in a vinyl pool.
    Aug 2012
    Nebraska
    Here is the full report as of tonight:
    FC = 4.0
    CC = 0.0
    CYA = 55
    TA = 120
    pH = 7.8
    The water looks perfect, as it has all summer.
    Not sure what's making our eyes burn.
    I must admit I am baffled. There must be another irritant in the water, but all I have is a few "try this" suggestions in the dark.
    Have you added other chemicals like copper, silver, ammonia based algaecides, clarifiers, etc?
