Thread: pH up: when to add
    Charlotte, NC, USA.
    Question pH up: when to add
    My pH is a little on the high side. It normally stays around 7.5, but sometimes it starts creeping up close to 7.8. I have some pH down to fix it, but wanted to know if it was OK to put it in at night when I add my chlorine. Or is it best to space things out. I wanted to put it in now, but I want to swim in a couple of hours. I'm thinking that might be dangerous though b/c I don't know how long it will take to become completely diluted in the water. Any advise? When do you normally add this stuff?
    Oops, edited to add my other info, not sure if it is all relevant to the question though:
    pool is AG 28ft w/dished out deep center, approx 22,000 ga.
    Using BBB methods
    FC 6
    CC 0
    TC 6
    pH in between 7.5 and 7.8
    TA 100
    CAL 190 (vinyl liner though, so irrelevant)
    CYA 35 - 40
    temp 81
    Indiana.
    Default Re: pH up: when to add
    pH up will raise the pH. Add pH down or muriatic acid to lower it. I usually add pH changing chemicals in the morning and chlorine in the evening. That's just my routine, and it works out for water testing at about 12hr increments when I'm trying to move the pH. I at least wait a couple of hours after adding pH moving chemicals before adding bleach, but I don't know if there's any validity to my strategy.
    Charlotte, NC, USA.
    Geez, thank you for pointing out my silly mistake. I actually do have "pH down" not "up." Don't know why I mis-typed. Brain fart???? Anyway, thanks for replying. I'm thinking it's not good to add a bunch of different stuff at one time, but hubby says "they exist in the water all together at the same time." Not sure I'm on board with his theory though.
    FYI: pH Up is a VERY expensive packaging of soda ash (sodium carbonate). It's sold in grocery stores as washing soda as well.
    Alternatively, you can use 20 Mule Team Borax from the grocery store to raise pH. It has fewer side effects than soda ash, and is safer to handle.
    pH Down is a VERY expensive packaging of dry acid--can't remember the chem name but there are lots of generic brands of dry acid. Or you can use muriatic (hydrochloric) acid, available at most hardware and tile stores.
    Total Alkalinity Raiser is a very, VERY expensive packaging of ....BAKING SODA! That's right, it's the same as Arm&Hammer sodium bicarbonate.
    "Liquid Chlorine" is usually the same as ultra bleach or a double strength version of ultra bleach. Sometimes it's more expensive than bleach, sometimes cheaper. But you can ALWAYS use ordinary bleach.
    See? We just saved you a TON of money going forward!
    waterbear's Avatar
    St. Augustine, Fl
    Quote Originally Posted by CarlD
    FYI:
    Sodium Bisulfate is the ingredient.
    Quote Originally Posted by waterbear
    Thanks, Evan. I went blank on it and was too lazy to look it up!
