Thread: Used to have a pool service
    Jul 2014
    Default Used to have a pool service
    I decided to discontinue pool service last year and was doing okay until this summer when I found out the CYA level was too high. Since then, I have been searching the internet for help and found this website.
    Default Re: Used to have a pool service
    If your CYA is high, you URGENTLY need to raise your chlorine level. Hopefully, you'll be able to do so before algae gets established in your pool.
    1. Get a local cheap OTO / phenol red drops test kit (Walmart, etc) and add chlorine till you read the DARK yellow range on the kit.
    2. Order a K2006, so you can actually determine what your chlorine level should be (10% of your CYA level), and keep it there. http://pool9.net/tk/ Be sure to watch the videos before you use the kit. Ignore the booklet that comes in the kit.
  1. Which pool robot has the best service, reliability and warranty?
    By titaniummd in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-21-2013, 01:12 AM
  2. Need some advice please, Pool service providers responsibilities
    By kiko64 in forum In-Ground Pool Construction and Repair
    Last Post: 03-07-2012, 01:47 PM
  3. How many people uses pool service
    By teo_dk in forum General Interest
    Last Post: 06-17-2011, 01:03 PM
  4. Pool Service in Arizona
    By ScottsdaleSwim in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-23-2007, 12:48 AM
