Page 3 of 3 FirstFirst 1 2 3
Results 21 to 23 of 23
Thread: Need advice on cloudy Intex Pool . . . but I don't want a K2006
  1. #21
    Jul 2014
    RI
    Red face Re: Need advice on cloudy Intex Pool . . .
    Got it. Thanks everyone so much!
    I've actually been surfing around the site in anticipation of getting a permanent above ground at some point. What a great resource you all are. I'll be sure to do a lot of homework before buying and won't be taken for a ride (again - I never knew the pool stores will commonly try to sell you a bigger filter system than you need).
    It's hot and humid here in RI today and the kids can finally get back in the pool!
    Take care and thanks again - hopefully I can take it from here!
    Ellen
  2. #22
    Default Re: Need advice on cloudy Intex Pool . . .
    You are welcome. If you need us again, we'll be here!
  3. #23
    Quote Originally Posted by EllenF View Post
    I never knew the pool stores will commonly try to sell you a bigger filter system than you need.
    Conventional AG pool sales typically include a bigger pump than you need -- not a bigger filter. Normally, the pump is too big, and the filter is too small.
    Soft-side (Intex, etc) pool systems (pump + filter combo) are better matched . . . they are BOTH too small. That's why it's so hard to clean up a soft-side pool once it is cloudy.
  1. Intex pool setup advice
    By mitchlog in forum Intex-type Pool Setup & Operations
    Last Post: 06-11-2014, 12:20 AM
  2. Still have green, cloudy water after following pool store advice
    By Jess09 in forum Dealing with Algae & Slime
    Last Post: 07-18-2013, 03:36 PM
  3. Looking for AG Advice - Researching Intex pool purchase
    By littlemisszoom in forum Above-Ground Pool Construction & Repair
    Last Post: 06-17-2011, 06:34 PM
  4. Conflicting Advice and a slightly cloudy pool
    By MVB621 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-02-2010, 11:21 PM
