Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 34
Thread: PH levels
    Jul 2013
    NJ
    Default PH levels
    Will using Baking Soda raise ph in a salt water pool?
    Jul 2013
    NJ
    Default Re: PH levels
    Sorry I had an algae problem I think I'm good now. But now the pool is cloudy and was told by a neighbor that baking soda should help it has for him. My fear is it will raise my ph to high and cause other problems. My ph runs on the high side to begin with I don't want to over do it but I'm so over the pool not being clear. Thanks.
    I have a sand filter, in ground liner with a swcg.
    Jun 2014
    New Jersey
    As Watermom said, baking soda is used to raise alkalinity. It isn't going to help you clear your pool. Do you have a test kit? If not, make the investment.
    Btw... I'm in Burlington County, NJ. You?
    19.5k gal, 16x32 vinyl liner, sand filter, 1hp single speed pump, K-2006 test kit. PF=6
    Jul 2013
    NJ
    Thanks guys... And yes I'm in Burlington Cty...
    I'm not sure if I still have algae or not? The water looks a lot better this am but I brushed the deep end and it's still has some settlement of something? Do I still have algae?
    Yes I have the K2006c based on your suggestion last year.
    FC 5.6
    CC 1
    PH 7.4
    CYA 50
    TA 80
    Jul 2010
    Largo, Florida
    You've got something growing. You should shock (chlorine consistently at 15ppm) until you have zero CC reading and a clear looking pool.
    Jun 2014
    New Jersey
    I'm just a couple 295 exits south of you
    With a CC @ 1, you likely still have something left to kill (algae or otherwise) in the pool. Ideally, you want that number to be zero. A good shock is in order.
    Please place in your signature the type, size, and equipment your pool has so we can better help you.
    Jun 2014
    New Jersey
    Quote Originally Posted by kelemvor View Post
    Beat me to it
    Jul 2013
    NJ
    I have a 22 x 39 mountain shape so not 100% sure on total gallons. 8 ft deep end I guess 3 ft low end. I've always guessed 27k gal. Sand filter, liner 1 hp SWCG
  1. cya and other levels
    By dalejanus in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-11-2012, 12:25 PM
  2. Can't get CYA levels up
    By astargel in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-04-2010, 05:40 PM
  3. My levels, are they okay?
    By Digger in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-20-2010, 02:23 PM
  4. CA levels
    By wilcfr in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-11-2008, 12:07 AM
  5. pH levels and SWG
    By keastman in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-29-2006, 01:06 PM
