Results 1 to 9 of 9
Thread: Endless Pool Hydraulic Oil Filter
    May 2014
    Plano, TX
    Default Re: Endless Pool Hydraulic Oil Filter
    Having worked in hydraulics for several years, I can tell you that there are only a hand full of filter manufacturers, and almost NO truly "specialized" filters. It may take some chasing to find the right one, but I'll bet EPI just has a standard filter branded with their name.
    Good luck!
    Pappy
    I'm wondering if their hydro fluid is any different than what's used in snow plows and bulldozers. Of course, I doubt you have many plows in Mississippi....but they are pretty common up here. I keep a small Fischer "Homesteader" for my driveway and keep fluid around for it.
    They use a biodegradable hydraulic oil. I don't know if this is due to an effort to 'be green', or if the bio-oil is less likely to foul the pool if something leaks.
    Biodegradable hydraulic oil? Wouldn't that need to be replaced VERY frequently? I wonder if it's some sort of vegetable oil like castor oil or corn oil.
    Jul 2014
    Mississippi
    According to the spec sheet, we should not have to replace the oil for 3 years. We are using Mobil EAL 224H biodegradable. OF COURSE, it supposedly won't last as long in a hot climate (we just finished 17 consecutive days over 90 degrees - it rained today so it only got to 85... steambath anyone?).
    I never heard back from Baldor via email. I'll see if I can call them Monday (if I can remember).
    7x14 Endless Pool 2002 model, installed July 2014 with deeper option, 3000 gals., Nature2 water treatment, Pinnacle 3/4 HP pump, K-2006
