nefretrameses
My pool had three 1-1/2 inch lines on the suction side of the pump all teed together to the 1-1/2 inch pump fitting. Then 1-1/2 to the filter and back to the pool. At the pool there's an in-floor cleaner valve to four circuits. I had the opportunity to change to 2 inch from the pump discharge to the in-floor valve - about 60 feet total. My discharge pressure dropped by about 1/3. Your fittings will cause some loss, but the 2 inch pipe is really gonna be the biggest factor. You can use two 45 degree fittings instead of 90's and save a bit more.
Not sure about your combo valves or adhesive. There should be a way to adapt PVC to CPVC, but its not in my bag of tricks to know how. If your heater wants a 6 inch nipple, its probably for "straightening out" the water stream before it gets inside. Not sure how much you want to compromise that, but again, its not really in my bag of tricks. Sorry.
