Everything is now complete at the equipment pad... I even installed the firemans switch relay, wired it to enable only via firemans switch and the pump on high. I also have the high/low speed relay installed as well (pump is always at low speed unless the timer commands the pump to run at high and I have a seperate timer for pump power altogether). I also have the ability to switch the pump to high from low and it will allow the heater to run regardless of the status of the firemans switch since it is on manual override.
Pics of the equipment pad:
And the plumbing waiting out by the pool location:
Now I just need some dry weather for about a week to get the limestone down and to start paving the patio... I don't think I am going to get to install the pool this year...
