Results 1 to 10 of 14
Thread: location of main drain pipe
    Default Re: location of main drain pipe
    Actually, I don't have enough money to make me a target for any attorney with an IG above the double digits!
    My caution is more ignorance based: the sort of situation you're in tends to include surprises, even for very experienced service guys.
    I would recommend checking the hydrostatic valve, simply because it's (a) a likely cause, and (b) one that can be repaired. Some of the other possibilities involve MAJOR expenses and demolition. In those cases, pool owners often end up abandoning their main drains.
    On a positive note, the mere fact that you've repeatedly had water enter the pool via the hydrostatic valve greatly increases the chance that that valve IS the problem.
    Aug 2014
    South Carolina
    Ah-ha very good. :^) We've never used the main drain. What we've done is go out to the pool about 6 pm when the wind has died down, cut on the pump, remove the leaves with the screen thing on the end of a pole, and then have the pump shut down around 11pm using a timer. So we run the pump for about 5 hours a day after getting the leaves off the surface of the water so that the skimmer won't get clogged up. That has kept the water clear, and we don't have to worry about the pool pump getting starved of water and burning it up. So the easy thing to do here would be to somehow cap the MD and continue what we've been doing. What I have it capped with now is PFD foam wrapped in plastic wrap with three ten pound weight plates on it. But it doesn't provide a good seal, so the pool is still leaking a lot. Or maybe it is sealing the MD and there's a leak somewhere else. But I carefully went around the pool with ink and a syringe and tested every port and interface, and couldn't see that the ink was being sucked in anywhere.
    Anyway, I will just keep it capped until we get another dry spell. Then I'll drain the pool and replace the valve. Then I'll go from there.
    Thanks,
    S
    You're welcome.
    Aug 2014
    South Carolina
    So what's the best way, or what are some options, with respect to capping the main bottom drain? My goal in this instance is to control for any leaks which might be associated with it. The main drain hasn't functioned properly for over ten years, and I assume this is the case because there's a hole in the return pipe which allows too much air to bleed in while the pump is trying to suck water through it. The current main bottom drain does does have a pressure relief valve in it, and I may replace it by way of determining whether that's the source of the leak. What I would like to do is cap the bottom drain, but have an easy way to uncap it if needs be: say, if I decide to try to repair the return pipe, or replace the pressure relief valve.
    Right now I'm a few hours away from having the pool drained. I'm going to remove the bottom grate, and also the pressure relief valve if possible, so that I can get serial/parts number.
    Thanks in advance,
    Scott
    Aug 2014
    South Carolina
    After a hiatus, I've decided to dive back into this pool project. My pool has a leak, and it's probably associated with a faulty pressure relief valve, or perhaps a pipe separation at the bottom drain due to the pool having floated out of the ground @ one inch at one side of the deep end. It's been like that since before we owned the house, and the pool didn't have a leak until about two years ago. So I don't think the leak is a function of the pool floating up out of the ground a bit.
    I decided to try to remove all the groundwater from around the outside of the pool. That way I can work on the main drain, pressure relief valve, and repaint the pool surface. My water table is @4-5 feet below the surface of the ground, and that's where the water level in my pool is. I've been able to drill down about 12 feet using the method described here: http://drillyourownwell.com/index.htm I can't go deeper than 12 feet because gravel accumulates at the bottom of the well hole, and my (metal) bit can't get through the gravel. But maybe 12 feet is enough, as the pool is 8 feet deep.
    I haven't hooked up the well pump yet. What I'm hoping is that I can pump out water, and as I do so the pool will drain as well, through where I presume the leak is. In other words, as I lower the water table in the immediate vicinity of the pool, water in the pool will drain. Presently the water level in my pool mirrors the water table outside of the pool, so this seems like a reasonable supposition.
    My questions:
    1) Let's suppose my DIY well and well pump won't drain all the groundwater around the pool. How does one go about achieving this? Do I hire someone to come out and dig a big ditch and put a pump in it? Does one drill through the bottom of the pool and pull the groundwater out through the hole?
    2) Let's suppose that I get "close" in terms of draining the water around the pool with my well and electric well pump, which is rated to pull water from as deep as 25 feet. So the water level inside the pool gets down to, say, three feet deep. I think I could then then go ahead and pump the rest of the water out of the pool and cap the bottom drain so I can paint the pool. I think it would be fine to do that, as I have drained the pool completely before without removing any groundwater at all, and the pool hasn't floated up out of the ground of the ground any more than the @inch is has already on one side of the deep end. (It's been like that since before we owned the house.)
    So, my question is, how do I cap the drain so that water can't get in or out, and I can repaint the pool surface?
    I would also remove the old pressure relief valve, replace it with a new one, and refill the pool to see if it holds water. If the pool still leaks, then I would want to cap the main drain somehow. I guess I could cap the drain hole, and leave the new pressure relief valve in so if people empty the pool of water it would fill back up with groundwater.
    But, again, there's zero paint on the sides of the pool. So I want to do that, too.
    Thoughts, advice?
    Thanks,
    Scott
