Re: Iron in water source
I'm pretty sure bringing the pH down was to get and keep the iron in solution to start then use HEDP to try to keep it in solution.
I believe the mechanism for removing iron with cal-hypo is to let the cal-hypo raise the pH causing the iron to drop out on the filter with the calcium precipitate. I would backwash before dropping the pH. Did you do it that way already or did you backwash after dropping the pH?.
