Results 1 to 10 of 27
Thread: New Pebble - first tests
    North Florida
    Smile Re: New Pebble - first tests
    Dave, you were right on. My chlorine has disappeared! We added 3-182oz bottles of 6% bleach late yesterday afternoon (546 oz vs 544 oz in Bleach Calc!). New readings fresh from the pool:
    pH 8.2- (rather than +) Total muriatic acid added is 1/2 gallon - we'll do more
    Total Cl 0
    Free Cl 0
    TA 110 (added 10# of baking soda last night)
    CYA less than 30 (redid this test, still not really confident in this measure, as the dot disappears(?) when the solution is right at the very, very top of the vial; another drop and it would spill over)
    Calcium hardness 70-80
    My Cl really "shocked" me, as there was no change in color for either test! Actually called the 800# to see what high chlorine would register on tests that only go up to 5.0 (I was hoping they'd say "clear"). They said I should see an intense orange color if I were holding Cl levels above 5. I can see I need to get a test that can measure high chlorine levels. Whenever Ben's kit arrives, will it register shock levels, I wonder?
    So, I'm guessing that I should continue to add Cl to shock levels until it can hold Cl overnight? - seems like I read that somewhere???
    Sandy
    Downingtown, PA
    Default Re: New Pebble - first tests
    Try to keep testing and adding Cl to the pool morning, noon and night to keep shock level of 15ppm. Also, continue running the filter 24/7.
    Outside of Philadelphia, PA
    18' x 40' IG - 22K gallons
    Sylvan Gunite Pool (1979)
    Plaster re-done (1997)
    duraleigh Guest
    Hi, Sandy,
    get that pH down. Use the bleach calc....shoot for 7.2 - 7.4
    Ben's kit will measure as much Cl as you'll ever put in the pool....accurately.
    If you've used up your bleach, I would buy a tub of Cal Hypo...you need to get your calcium up, too.
    Yes, keep your Cl at shock value 'til it virtually stays constant overnight. 18-20 would not be too high in your pool.
    One more thing, Sandy.......GET THAT pH DOWN!
    North Florida
    OK,OK,OK...now you really think I should bring my pH down???
    Actually, I've just added another 1/2 gallon of muriatic and will go back and recheck the actual amount I should add to reduce my pH in a reasonable step, not baby steps. At my current rate, I won't hit target pH until Labor Day. I've added another 546 oz of 6% bleach this AM, even though I know a lot will be used up by the sunlight and rendered less effective by my higher pH.
    I'll head out to get some CalHypo today, as it'll only take one more shock treatment to use all the bleach I bought yesterday.
    Thanks again for bearing with me.
    Sandy
    duraleigh Guest
    It's always very easy to assist folks who post good test results and don't get too side-tracked with all the "magic bullets" the pool store offers.
    North Florida
    A mere 5 hours after adding all that bleach and muriatic acid, my chlorine readings (double-checked both total and free) were at 0 again!! Gosh, how much stuff do I have in my pool??? However, my pH had dropped to 7.2.
    So even though I added a shock's-worth (546 oz) of 6% bleach in the early morning, I added another 546 oz late in the afternoon. Four hours later, just about dark, I tested and got:
    Cl 5+
    Free Cl 5+
    pH 7.8?? (really hard to get a good read)
    Added nothing last night
    This morning's readings:
    Cl 5+
    Free Cl 5+ (it held!)
    pH 7.5
    TA 80
    Calcium hardness 70 (vial started at a light pink rather than the red it has been previously, color turned to a light blue/green after 7 drops, color didn't intensify with more drops)
    Pool water decidedly more blue but has had increasing gray cloudiness in last 2 days. Pool is Ocean Blue Pebblesheen which should be a dark but very true blue with no green when fully cured. Clear areas get this gray cloudiness when agitated. Definitely gets stirred up and hazy when I brush.
    My plan for the day is to buy some distilled water to see how high my chlorine level really is. My understanding is that I can only use the shot glass method for the total cl (OTO) test, correct? It won't work for the free chlorine test (2 reagents)? Then if I need chlorine, I'll use the CalHypo I got yesterday. Because I wasn't able to accurately test to see if I ever got to 15ppm in chlorine, should I still keep shocking? Shock til the cloudiness disappears? Or does the fact that I was able to keep some chlorine in the pool overnight mean I've killed everything that needed killing and the haziness is just the "dead bodies"?
    Thanks for the help.
    Sandy
    duraleigh Guest
    Hi, Sandy,
    You're making progress but you need to keep your pool at shock level 'til your water looks like you want it.
    That cloudiness is dead algae but it's probably not all dead......because your still consuming Cl.
    I would recommend you use the color of your water as the bellweather. When it's crystal clear....you're done. More precisely, you're Cl should not drop from shock level more than 1-2ppm overnight.
    Test right at dusk and add Cl. Then test first thing next AM to see where you are.
    Meantime, let your filter do it's job. Stir up the cloudiness or vacuum it up and let that sand filter clear your pool.
    Nice work to this point. May take a while longer but keep the Cl in there and run that pump 24/7, backwashing when necessary.
