Re: Bonding equipment question
I disagree that it's stupid and I agree that you should bond the heater. You can't count on the black iron pipe for continuity - and - do you want the gas line in your house carrying current?
The code you have to comply with is not the NEC but whatever codes your municipality has adopted. Can you check with your electrical inspector? I would bet that a stainless screw holding the bonding lug to the heater would pass as long as the lug has a good electrical connection to the heater (no paint under it).
I noticed that you've used split bolts to connect segments of bond wire. This would not pass inspection in my town - our adopted code calls for a single wire or thermally welded. Again check your local enforcement authority.
