Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 37 of 37
Thread: Test Results are in :(((
  1. #31
    Sep 2011
    Southern AZ
    Default Re: Test Results are in :(((
    Oh what I meant by shocking was using CalHypo.
    Anyway last night I have used 2 lbs 56% CalHypo and let the pump run, this morning it is clean and clear
    Due to lack of CYA chlorine from CalHypo tends to disappear by late afternoon, pool receives direct sun for at least 8-9 hours a day and I am in Southern AZ. But then I use it again same night (1 lb bag) and let the pump run. Meanwhile I am also using the tablets (TriChlor) to build up the CYA levels
    Here are the test results as of 1 pm today (this after using 2lbs CalHypo last night after hit by a rain storm).
    FC 3.8 ppm
    CC 0.1 ppm
    pH 7.6 (down from 7.8)
    TA 120 ppm (unchanged)
    CH 140 ppm (up from 110)
    For the filter I have Clean & Clear plus 320 (pentair) with new cartridges.
    Matt
    11,000 gal inground freshwater concrete pool & SPA, PebbleTec, Clean and Clear+ 3200, 1hp motor, last Drain & Fill 8/10/2014. Trying BBB method.
  2. #32
    You'll want to keep using that Cal-Hypo or add calcium powder as you have a PebbleTec pool and your CH is still 60ppm under the recommended range of 200-400.
    BigDave's Avatar
    I'm pretty sure CarlD warned you earlier, but, I'll say it again since you are using trichlor and cal-hypo at the same time. Don't let undissolved trichlor and cal-hypo near each other.
  4. #34
    Sep 2011
    Southern AZ
    @ Carl & Big Dave thanks for the heads up on cal hypo and trichlor.
    As of today I have actually stopped using trichlor as my test results are ;
    FC 1.6 ( this after staying under the sun whole day and last dichlor was added 48 hrs ago )
    CC 0.1 ppm
    pH 7.8
    TA 100 ppm (down from 120 five days ago)
    CA 170 ppm (up from 140 ppm 5 days ago, it is rising nicely, Doheny's CalHypo speeded up the process, used 3 lbs in 5 days)
    CYA 35 ppm (black dot disappeared after 40 ppm but before 30 ppm so I am taking the average)
    As of today I have stopped the trichlor, I was very surprised how quickly Pool Brands tablets was adding CYA. I have used probably about 10ea 3 inch tablets to bring it to 35 from 0, and it was not adding much chlorine. Now I guess I know why my CYA shot upto 200 pm before I drained the pool.
    Plan is to continue with dichlor until I reach somewhere around 200 - 220 ppm CA and then to switch to bleach and add other Bs as needed. I will be checking chlorine and pH daily with dye based test and running full test about twice weekly.
    I hope I can keep the pool in balance.
    Thanks for all the help I've received from this forum, I really appreciate it.
    Matt
  5. #35
    I think you mean cal-hypo, not di-chlor, as di-chlor adds CYA faster than Tri-chlor. Di-Chlor does NOT add calcium, Cal-hypo does. If your CYA goal was higher (like for a SWCG or southern clime), the tri-chlor would be good as it would lower your pH as well.
    FYI: Tri-chlor add about 6ppm of CYA for every 10ppm of FC, while Di-chlor add about 9ppm of CYA for every 10ppm of FC, but tri-chlor is much more acidic.
    Sep 2011
    Southern AZ
    I did mean CalHypo )
    Since I'm southern Climate (I'm in S. Arizona) what should be my ideal CYA level ? Is 35 ppm too low ?
    Matt
  7. #37
    BBB - it's not a recipe, just a catchy name for using only the chemicals your pool needs and finding them at reasonable prices
    Good explanation.
    @ MattinAZ => 35 is pretty low. 80 will make things easier . . . IF you continue to use cal hypo. But if you use dichlor / trichlor, it will go up on its own, more than you need, so you shouldn't add any.
  1. Test Results...I think!
    By Dw4scoobydoo in forum Pool Chemistry for Intex-type Pools
    Last Post: 08-07-2012, 10:29 AM
  2. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  3. Got my kit - 1st test results
    By cantileveredge in forum DPD-FAS based testing
    Last Post: 07-17-2006, 10:17 PM
  4. Just got kit - first test results
    By lisak in forum DPD-FAS based testing
    Last Post: 07-16-2006, 09:25 PM
  5. First 234s test results and warning about pool stores' results
    By SoCalBoo in forum DPD-FAS based testing
    Last Post: 06-16-2006, 02:48 PM
