Page 16 of 23 FirstFirst ... 6 14 15 16 17 18 ... LastLast
Results 151 to 160 of 228
Thread: Clear, but no chlorine???
  1. #151
    BigDave's Avatar
    Default Re: Clear, but no chlorine???
    As long as it has pool water flowing through it, I wouldn't worry about it.
  2. #152
    mary jo is offline Subscriber Thread Analyst mary jo 0
    Aug 2014
    Batavia, IL
    So continue to keep the pool at shock level- 30- and see what happens to the CC.
    btw: the skimmers again have a very thin line of sticky, greasy, black stuff around the waterline. I was going to wet a cloth with chlorine and wipe. Never had this before last Sunday.
    15K gal, 15x30 rectangular, in-ground, vinyl liner, Pentair ¾ HP Whisperflo on 24/7, Pentair Cartridge Filter(CCP240), Heater (gas), Automatic Pool Cover
  3. #153
    BigDave's Avatar
    The shock seems to be working, I wouldn't stop now. Like PoolDoc said - clean that goo off while you can.
  4. #154
    Might try using a paste of baking soda and water to scrub it with.
  5. #155
    Virginia
    Quote Originally Posted by mary jo View Post
    I occasionally get the same black goo in the skimmers. I just clean it off when I notice it. It's been happening for years, but I've never notice a negative impact on the pool from it.
  6. #156
    Aug 2014
    Batavia, IL
    A big thank you to FormerBromineUser- yesterday I got a "house call" from her to look at my pool - an extra pair of eyes might help. Everything that could be cleaned was cleaned EXCEPT----when I turned the in-line chlorinator OFF several weeks ago, I forgot to take the pucks out! Luckily FBU caught this and the petrified pucks (about 6 of them) were removed and the empty tower cleaned (with hose water). There was a rust-colored looking stain on the tower walls, a bit of sediment on the bottom, so I soaked it w/ hose water and sprayed it out w/ the hose on jet spray setting. It does look much cleaner and water in it is clear, so I turned it on just a bit to let water trickle thru it- there's no shut off value for the chlorinator and Nature2 unit (which are located next to each other on their own line).
    Not sure if that was a contributing factor, but it's now empty and clean.
    Numbers:
    Yesterday FC went from 30 to 27 (dawn to late afternoon) so I added about 1/2 jug of bleach.
    Last night tested @ 8:30pm FC=30 CC=2.0
    This morning tested @ 7:15am FC=29 CC=2.5
    I didn't get to the brushing yesterday- will do it today.
  7. #157
    BigDave's Avatar
    Sounds good, 0.5ppm is the error in the test so those readings are pretty much the same. Have you had any sun?
    I'd like to try a little experiment If you'll indulge me. For the next FC/CC test, use two dippers of DPD powder. Post any observation you have about the test.
  8. #158
    Aug 2014
    Batavia, IL
    Yes, we had lots of sun yesterday, and today as well (so far). Should I do the 2 scoops when I test this afternoon or wait until this evening?
    Also, a question: my husband is coming back in town and has already asked me if he can swim tonight. I now know (and now he knows) it's safe to swim @ FC30, but will it mess up the FC/CC levels if he does? I'd rather wait until we're in the clear- POP, right- but wanted your opinion on whether this would set us back any.
  9. #159
    BigDave's Avatar
    Go ahead and swim - in an old suit. Next time you test, I'm curious if you'll see a difference at 30ppm FC.
  10. #160
    Jul 2013
    Northern Illinois
    Just sterilize the hubby before he jumps in!
  1. Clear Pool but cannot maintain free chlorine level?
    By Mr.Mooks in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-20-2011, 08:47 PM
  2. high chlorine, but crystal clear!
    By katydid in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-20-2011, 09:14 AM
  3. OK It's clear now what do I need to do?
    By joanie109 in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 08-19-2006, 05:46 PM
  4. Clear solar cover options? Magni Clear?
    By PoBoy in forum Pool Equipment & Operations
    Last Post: 07-10-2006, 12:01 PM
  5. Pure and Clear SWG
    By superjet in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-23-2006, 12:30 PM
