Page 7 of 23 FirstFirst ... 5 6 7 8 9 17 ... LastLast
Results 61 to 70 of 228
Thread: Clear, but no chlorine???
  1. #61
    Jul 2013
    Northern Illinois
    Default Re: Clear, but no chlorine???
    Any CC?
    Great minds.....
  2. #62
    BigDave's Avatar
    How about Combined Chlorine?
    Thanks FormerBromineUser!
  3. #63
    mary jo is offline Subscriber Thread Analyst mary jo 0
    Aug 2014
    Batavia, IL
    The test sample was barely pink (after adding the 5 reagent drops), then one drop of R-0781 turned it water clear, so <= 0.5
    15K gal, 15x30 rectangular, in-ground, vinyl liner, Pentair ¾ HP Whisperflo on 24/7, Pentair Cartridge Filter(CCP240), Heater (gas), Automatic Pool Cover
  4. #64
    Aug 2014
    Batavia, IL
    Just had another thought : it looks like rain here. Should I cover the pool if we do get rain? I've never had rain water in my pool before ( another big rule from the pool installers which I've always adhered to- always cover the pool when it rains.... Rainwater is bad).
  5. #65
    Jul 2013
    Northern Illinois
    Please continue to measure FC and CC after the last dose in the evening has had a chance to mix in
    Are you giving it an hour or so to circulate and then checking to make sure you hit 30FC?
  6. #66
    Jul 2013
    Northern Illinois
    Huh???? I OPENED mine at 5-ish this morning so I could get the rain in my pool.
  7. #67
    Aug 2014
    Batavia, IL
    Oh- I see. At night, dose the pool with bleach to get a FC of 30, wait an hour and THEN take another reading for the night. Sorry, my brain is slow.
  8. #68
    Jul 2013
    Northern Illinois
    Yes! You need to make sure you've reached the target FC. Under shock conditions you don't want to make assumptions. (Once your demand is gone, you won't have to do this).
    Have you checked your CYA lately? BigDave mentioned the possibility of some conversion of CYA and I don't have time to back track to see when you last checked it.
  9. #69
    Aug 2014
    Batavia, IL
    Last week (august 11) my CYA tested at 150. I typically do the test 3 times and average. (since it's a more subjective test than most- i think). I have not added any hose water since last week, but I will test it again today.
  10. #70
    If you tested CYA on August 11, no need to do it again. Just wastes reagents.
  1. Clear Pool but cannot maintain free chlorine level?
    By Mr.Mooks in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-20-2011, 08:47 PM
  2. high chlorine, but crystal clear!
    By katydid in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-20-2011, 09:14 AM
  3. OK It's clear now what do I need to do?
    By joanie109 in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 08-19-2006, 05:46 PM
  4. Clear solar cover options? Magni Clear?
    By PoBoy in forum Pool Equipment & Operations
    Last Post: 07-10-2006, 12:01 PM
  5. Pure and Clear SWG
    By superjet in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-23-2006, 12:30 PM
