Results 1 to 10 of 228
Thread: Clear, but no chlorine???
    BigDave's Avatar
    Default Re: Clear, but no chlorine???
    Sounds good, 0.5ppm is the error in the test so those readings are pretty much the same. Have you had any sun?
    I'd like to try a little experiment If you'll indulge me. For the next FC/CC test, use two dippers of DPD powder. Post any observation you have about the test.
    mary jo is offline Subscriber Thread Analyst mary jo 0
    Aug 2014
    Batavia, IL
    Yes, we had lots of sun yesterday, and today as well (so far). Should I do the 2 scoops when I test this afternoon or wait until this evening?
    Also, a question: my husband is coming back in town and has already asked me if he can swim tonight. I now know (and now he knows) it's safe to swim @ FC30, but will it mess up the FC/CC levels if he does? I'd rather wait until we're in the clear- POP, right- but wanted your opinion on whether this would set us back any.
    15K gal, 15x30 rectangular, in-ground, vinyl liner, Pentair ¾ HP Whisperflo on 24/7, Pentair Cartridge Filter(CCP240), Heater (gas), Automatic Pool Cover
    BigDave's Avatar
    Go ahead and swim - in an old suit. Next time you test, I'm curious if you'll see a difference at 30ppm FC.
    Jul 2013
    Northern Illinois
    Just sterilize the hubby before he jumps in!
    Aug 2014
    Batavia, IL
    It rained last night, so hubby is going in the pool this morning (after playing tennis). I'll suggest he rinse off beforehand.
    OK- BigDave- I must admit when you mentioned experimenting with 2 scoops of DPD my first thought was: hmm, you are testing for possible user error, which, given my # of rookie mistakes I'd say makes sense… but it turns out i DID get different results.
    Yesterday's testing (8-28) The pool's numbers @ opening: FC=29 CC=2.5 Brushed the pool.
    I ran FC/CC tests @ 4:00pm, 10ml sample, added my standard "1 heaping scoop" (because heaping is my standard), and got: FC= 25. CC=3.0
    Same test w/ 2 scoops: FC=27. CC= 2.5
    Then I tried 3 scoops: FC=31. CC=2
    THEN I tried 1/2 scoop: sample "flashed" pink and then went clear again.
    Hmmm- added a jug of bleach to the pool and waited several hours.....
    Yesterday evening @ 8:30pm I tested using 1 and 2 scoops to see what would happen:
    1 scoop: FC =30. CC=3.0
    2 scoops: FC=32. CC=2.5
    Did 2 scoops again: FC=32. CC= 2.5
    This morning- tested @ 7am:
    1 scoop FC=30 CC=2.5
    2 scoops FC=32 CC=2
    what's going on- or am I just an erratic tester?
    also: just tested TA and pH: pH off the chart (but you mentioned this would happen w/ high FC), but
    TA went from green to blue to pale yellow (after 14 drops). ???
    THIS is normal random variation in test results.
    HIGH chlorine bleaches out low levels of DPD; this is ALSO a typical result.
    THESE are also normal random variation in test results; statistically speaking, they are identical results.
    2 scoops FC=32 CC=2
    Aug 2014
    Batavia, IL
    OK - good to know. I will continue on using 1 heaping scoop.
    what about the yellow TA reading?
    btw: hubby swam in the pool this morning- no skin or eye issues. sides and bottom squeaky clean. he said when you are actually in the water it does smell like a hotel pool.
    BigDave's Avatar
    Erratic tester, nope, your results are consistent. The second scoop can make the endpoint more clearly defined and at the comparatively high chlorine level you have, I wanted to see if insufficient DPD might be influencing the test. Apparently it is. I think it's best to maintain the shock level a bit longer as yesterday's chlorine loss was about 5ppm and (by any measure) the pool still has significant CC. Can you supply of DPD powder survive 2-scoop testing? Morning and evening is plenty often enough testing now.
    Dave, did you see Ben's post above?
