Results 1 to 10 of 228
Thread: Clear, but no chlorine???
    BigDave's Avatar
    Default Re: Clear, but no chlorine???
    Looking good. I agree with CarlD, don't add bleach and see if the CC is 0.5ppm or less this evening. If it's not, bring it back up to 30ppm. CC measures a lot of different chemicals most of which smell, taste, and feel bad. The time it's taken to make progress in your pool suggests that you've had some of the more complex combined chlorines that are harder to break down.
    mary jo is offline Subscriber Thread Analyst mary jo 0
    Aug 2014
    Batavia, IL
    Well, yesterday evening FC=25, CC=1 (lost 2ppm all day, had 3 people in the pool).
    Added 1 jug of bleach @ 8:00, tested @ 10:00 pm FC=30 CC=1
    This morning tested @ 7:00am FC=28 CC=1
    It's a cloudy, rainy Labor Day here.
    15K gal, 15x30 rectangular, in-ground, vinyl liner, Pentair ¾ HP Whisperflo on 24/7, Pentair Cartridge Filter(CCP240), Heater (gas), Automatic Pool Cover
    BigDave's Avatar
    Sounds like progress to me. 3 people in the pool with no increase in CC. Shame about the weather - maybe it will get better this afternoon.
    Aug 2014
    Batavia, IL
    It turned out the weather did get a bit sunny as the day went on. Hubby went in the pool again (at night): water felt squeaky clean (opposite of silky soft?),smell of CL but no bitter taste…still getting a slight black ring around the skimmer.
    Yesterday: morning FC=28 went down to FC=26 by evening. CC=1 again.
    I added a jug of bleach and re-tested at 11:00pm FC=31 CC=1
    This morning: tested @ 7:00am FC=29.5 CC=1.0
    any day now…….
    I'll bet you smelled chlorine when your husband went in the pool and when he came out. That's because any impurities on the skin get metabolized and...smell like "chlorine".
    Happens to me all the time. My FC will be solidly where it needs to be, there will be NO "chlorine" smell, I'll just stick my arm in and Bam! "Chlorine Smell"!
    I think it's time to let it drop.
    I haven't tested enough to be certain, but I suspect that, when FC levels are very high, spurious CC levels may appear. If your FC is stable overnight -- and 2 ppm is fairly stable.
    There may be some lingering chlorine demand. However, the best way to deal with it is probably simply to run FC levels equal to 10% - 15% of your CYA for awhile.
    Black ring around the skimmer can be from body oils and lotions OR it can be from plasticizers being released from the liner. If it's plasticizers, there is NOTHING you can do about that, except keep the pH reasonable (between 7 and 8).
    Aug 2014
    Batavia, IL
    OK- I just tested this morning @ 6:30am FC=26 CC=1
    Lost 1 ppm FC overnight (27 to 26)
    So if my CYA is 150 then I should let the FC lower to the 15-22 range and keep it there, and not worry about the CC? What if the CC level goes up?
    BigDave's Avatar
    Sounds right.
    If CC goes to 1.5, wait for it to come back down. If it continues climbing - it may take additional action. Let the pool get all the sun it can.
    Quote Originally Posted by mary jo View Post
    Also, you'll need to avoid focusing on problems you do NOT yet have. Just do the basics, and worry about the other stuff WHEN it becomes a problem; not before.
  1. Clear Pool but cannot maintain free chlorine level?
    By Mr.Mooks in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-20-2011, 08:47 PM
  2. high chlorine, but crystal clear!
    By katydid in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-20-2011, 09:14 AM
  3. OK It's clear now what do I need to do?
    By joanie109 in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 08-19-2006, 05:46 PM
  4. Clear solar cover options? Magni Clear?
    By PoBoy in forum Pool Equipment & Operations
    Last Post: 07-10-2006, 12:01 PM
  5. Pure and Clear SWG
    By superjet in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-23-2006, 12:30 PM
