Results 1 to 10 of 228
Thread: Clear, but no chlorine???
    Default Re: Clear, but no chlorine???
    I think it's time to let it drop.
    I haven't tested enough to be certain, but I suspect that, when FC levels are very high, spurious CC levels may appear. If your FC is stable overnight -- and 2 ppm is fairly stable.
    There may be some lingering chlorine demand. However, the best way to deal with it is probably simply to run FC levels equal to 10% - 15% of your CYA for awhile.
    Black ring around the skimmer can be from body oils and lotions OR it can be from plasticizers being released from the liner. If it's plasticizers, there is NOTHING you can do about that, except keep the pH reasonable (between 7 and 8).
    mary jo is offline Subscriber Thread Analyst mary jo 0
    Aug 2014
    Batavia, IL
    OK- I just tested this morning @ 6:30am FC=26 CC=1
    Lost 1 ppm FC overnight (27 to 26)
    So if my CYA is 150 then I should let the FC lower to the 15-22 range and keep it there, and not worry about the CC? What if the CC level goes up?
    15K gal, 15x30 rectangular, in-ground, vinyl liner, Pentair ¾ HP Whisperflo on 24/7, Pentair Cartridge Filter(CCP240), Heater (gas), Automatic Pool Cover
    BigDave's Avatar
    Sounds right.
    If CC goes to 1.5, wait for it to come back down. If it continues climbing - it may take additional action. Let the pool get all the sun it can.
    Aug 2014
    Batavia, IL
    Ok- so by wait you mean do not add any bleach, just keep testing and see if CC goes down ( or stays at 1) at lower FC level, yes?
    Yes. That's what everyone here has been telling you. Please re-read Ben's last post, above. He's said clearly that you need to let FC drop to 10%-15% of CYA and leave it there.
    So if CYA is 60, FC should be between 6-9ppm. If CYA is 90, FC should be between 9 and 13.5ppm. Etc.
    THEN see what happens to CC.
    Aug 2014
    Batavia, IL
    got it.
    Quote Originally Posted by mary jo View Post
    Also, you'll need to avoid focusing on problems you do NOT yet have. Just do the basics, and worry about the other stuff WHEN it becomes a problem; not before.
    Jul 2013
    Northern Illinois
    If you had the same storm we did, I hope you had your auto-cover closed! Debris is everywhere. Even my outdoor, heavy furniture was overturned. Large slate slabs on my table were lifted and askew. Wow. How is the pool doing since lowering FC?
    Aug 2014
    Batavia, IL
    Wow indeed- I heard 70 mph winds in the area. Incredibly, we only got a bit of rain, but closed the cover to be on the safe side.
    The FC has been dropping approx. 2 points during the day and 0-1 overnight. The CC has also been dropping!
    Yesterday morning FC=22 CC=0.5.
    Yesterday early evening (5:45pm due to rain) FC=20 CC=0. I double checked using a 25ml water sample to be sure and the FC=20.2 CC=0
    This morning tested @ 8:30 FC=19 CC=0.
    Sounds like you are done. To be safe, maybe one more day and then let chlorine drift down. Then you should be good to go and we can wrap up this incredibly long thread! Good luck!
