Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 33 of 33
Thread: Very Cloudy/Foaming issues
  1. #31
    Aug 2014
    Phoenix
    Default Re: Very Cloudy/Foaming issues
    Great info, thank you PoolDoc. I will get the materials, but before I do, I wanted to update where my pool is at as of today. Due to the weather systems rolling through AZ, it has been unusually cool for this time of year, so I jumped at the opportunity to partially drain my pool last night and refill. I also began to work at increasing my chlorine content since I was told it was quite low. With the partial drain (3 feet) and refilll, my applicable levels as of this morning:
    FC - 8ppm
    CC - 2ppm
    CH - 400ppm
    pH - 7.0
    Am I still ok to proceed with the process mentioned above? Also, I've attached a photo of my soupy pool. Water doesn't look bad, but once I kick that system on you can just see the nastiness being placed back in. This is what made the DE test very hard. Really wish I had the VAC 2 WASTE ability.
  2. #32
    1. Check the sand, as above, if possible.
    2. Do NOT cycle your pump on and off -- disable your timer for now.
    Instead, run it continuously till EITHER the water is clear OR the pressure has risen at least 6 pounds over the clean pressure. At that point, BACKWASH, then RINSE, before returning the multiport valve to FILTER.
  3. #33
    My bad. I was confusing this thread with another one.
    If possible, you should check your sand filter for LEVEL and for QUALITY. Get a bag of LABELED filter sand from a pool store (NOT: Lowes or Home Depot). Open the filter and check the sand LEVEL and quality (gummy, lumped, etc.) If there's sufficient sand, and it's OK, remove a handful and dry it on a pan in the over. Place some sand from the new bag side by side on a smooth white cloth (old pillow case) with the dried sand. See if they are the sand.
    Also if possible, replace the push-pull valve with a multiport valve. It will make managing your filter much easier.
  1. Water Foaming and Cloudy after Adding Bottle of ALgaecide
    By Bfloboyintx in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-19-2013, 10:31 AM
  2. New User & New Pool Owner - Chemical Issues (Chlorine & Stabilizer Issues)
    By mrsfish in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-10-2013, 09:31 PM
  3. Dusty Bottom/Cloudy Water Issues
    By MattTexas in forum Dealing with Algae & Slime
    Last Post: 07-04-2012, 01:00 PM
  4. Foaming when salt pool is generating
    By stonyloam in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-13-2011, 01:21 PM
  5. Help! Pool Cover Issues and Leak Issues
    By b2001 in forum Pool Equipment & Operations
    Last Post: 02-17-2008, 06:34 PM
