Hayward does make a power-flo Matrix 1hp 2speed 115V. I can't tell how much you'd need to change the plumbing.
I'm noticing that I would need to buy at least 1 HP to get a 2 speed. I'm running 1 HP right now and I think it may be too big. Leaning toward the Hayward 3/4 HP. I would save a little bit with that over what I have. The current pump is 6 years old according to Hayward.
Kevin
15x30 oval AG Pool. Hayward Power-Flo Matrix 3/4 HP pump. Hayward 16" sand filter. Taylor K2006 test kit.
Technically, there is no pump on the market, except maybe an Intex, that is a correct size for your filter. Your filter has a max flow rate of 35 GPM but ideally, you should be around 21 GPM with that filter.
However, the good news is that the Power LX 1 HP pump would provide about 49 GPM on high speed and about 24 GPM on low speed. So one option would be to replace the pump motor with a 2 speed motor and operate on low speed all the time.
Mark
With the short pipe run I have, my pump can do about 60 GPM, which is pointless if the filter can only do 35. I'm stepping down the HP 2 speed or not. Thanks for the input.
Kevin
I think mas985 is telling you that a 2 speed motor may be the only way to get as low as you need to go.
Just ordered the 3/4 HP Hayward Matrix from Amazon. Might have to put in a new outlet. My old pump has a twist lock cord. Think the new one is standard 3-prong.
Kevin
Or you can change the plug. Twist-lock is code in my town. Consider plumbing in a valve between the pump outlet and the filter to throttle the flow - that's still too much pump for that filter.
Twist-lock is code in my town, too, and the cord can't be more than 3' long.
I wish you had checked in before purchasing. The 3/4 HP matrix has close to the same flow rate as the Powerflo LX 1 HP. 48 GPM vs 49 GPM so you really are no better off. This is why it is generally a mistake to size a pump by the label HP rating. You would have been better off with a two speed on low speed.
BTW, how did you come to 60 GPM? That is much too high for that pump on such a small filter.
Mark
