Thread: Rainbow 320 does not drain when pump off
Threaded View
    Aug 2014
    Whidbey Island, WA
    Default Rainbow 320 does not drain when pump off
    Good morning
    am using Rainbow 320 while raising CYA
    is a new one so check valve should be fine
    directions say
    1. Turn control valve to the closed position. SHUT OFF PUMP.
    2. Wait one minute. This will allow water and fumes to drain from feeder.
    3. Leave control valve closed and turn on pump. The check valve will prevent water from
    entering the feeder.
    but #2 seems to not be true, water does not drain
    which is a problem cuz when you add tabs the water can splash or overflow and is nasty
    contacted Pentair who said
    1) relieve pressure by opening valve on the filter; did that and did not fix the problem
    next suggestion was
    2) unscrew Rainbow cap a bit, let water drain a bit, then screw cap back on
    but that loses prime (I guess not a big deal but...)
    any ideas why water does not drain as on the directions
    searched but did not find "the answer"
    by the way: tabs dissolve and feed Ok
    thank you
