all you need is bleach, a test kit, and more bleach. You want to filter out the baquagoo that collects in the filter so don't just recirculate. Keep backwashing the baquagoo out of the filter. Get the chlorine levels up to about 15 ppm and keep them there with bleach. The dichlor is stabilized chlorine and from what I understand the stabilizer will slow the process down. I am not an expert on the conversion but I have read through a lot of them on this forum. The more often you check the chlorine levels and make sure they stay at 15 ppm the faster the conversion will go. The biguinide will eat up the chlorine very fast. Some people have added bleach as often as every 2 hours to keep the levels up and have converted in only a few days that way. If you let the chlorine levels drop it takes longer.
