Results 1 to 10 of 16
Thread: Found this forum too late -- need some guidance on a conversion already begun
    Rehoboth, MA
    Default Re: Found this forum too late -- need some guidance on a conversion already begun
    You mentioned in your first post that you took the sand out of your filter and were waiting until the conversion was done before you put some back in. I didn't see anyone comment on this but I would think you want some sand in there to filter the goop you will be getting. After the conversion you will need to dump that sand and put in new sand.
    Good Luck
    Peter
    Thanks, Peter. Yes, I added the sand back in and have been filtering. When I woke up this morning I had yet to get any FC reading but this morning after several liters of ultra I've got it at at least 15-20 ppm which is encouraging. Even though I thought I was prepared for the hideous color, it was still shocking this morning to see the rusty water with tons of peachy baqua-crap floating all over the surface! It's difficult to skim but I'm just doing what I can.
    Since I live in AZ and expect the temperature to be 105 degrees today, should I even attempt to keep the FC level up or is that a lost cause? I'm off to buy more ultra bleach but just don't know if it's worth it to try and fight the sun all day . . . Anybody think it might be possible to keep it at that level?
    Thanks for all the help,
    Deborah
    Rehoboth, MA
    I would say the longer (and more frequently) you can keep the Cl up the faster the conversion will go. Even though you will be losing some Cl to the sun, some of it will be attacking the Baquacil so just do the best you can.
    Hang in there!
    Peter
