Results 1 to 9 of 9
Thread: BBB Fan with mustard algae in Intex pool
    Aug 2014
    Florida
    Default
    Thank you Carl. I won't add the baking soda. I usually use the Walmart 8.25, and will return to this after this. The Stop Yellow is sodium bromide. The pool is blue but cloudy today, and I checked the filter, and it is looking clean.
    Thank you for your advisement!
    Cherie
    I used test strips, but then took a sample to my local pool supply, so those numbers are from them. I will be glad when I have access to all the threads, but my pool looks to be clearing up just fine at this point.
    Thanks Watermom!
    Cherie
