Results 1 to 10 of 14
Thread: Is main drain necessary?
    mas985's Avatar
    Pleasanton, CA
    Default Re: Is main drain necessary?
    You will probably see a lot of opinions on this but I think you know my position if you read the thread.
    Without a main drain you will see better performance out of the skimmers. But the study I posted should be enough to convince you:
    http://www.poolforum.com/pf2/showthr...169#post126169
    Mark
    Virginia
    Quote Originally Posted by mas985 View Post
    Yes, I did read that (thank you for posting that ). Your posts are what have me pursuing how my pool behaves without the MD, or at least with flow from the MD greatly reduced.
    Do you know if the pressure drop I'm seeing at the filter when restricting the MD flow means there's also less flow coming out of the returns?
    I'm always learning something new here.
    mas985's Avatar
    Pleasanton, CA
    Turning off the main drain adds head loss to the suction (i.e two lines vs three) which in turn lowers flow rate but usually not by a lot. You should expect a slight drop in pressure because of this. However, the amount of total flow rate lost is less than the flow rate gain by the remaining skimmer so you come out well ahead from that perspective. I think overall, your pool will probably end up cleaner without the main drain, than with it.
    But given your run time (12 hrs), you might want to read the article in my signature on pump run time. Most pools only need about 3-4 hours per day. You can save a lot of energy and cost by reducing pump run time.
    Mark
    Virginia
    Turning off the main drain adds head loss to the suction (i.e one line vs two) which in turn lowers flow rate but usually not by a lot. You should expect a slight drop in pressure because of this. However, the amount of total flow rate lost is less than the flow rate gain by the remaining skimmer so you come out well ahead from that perspective. I think overall, your pool will probably end up cleaner without the main drain, than with it.
    Thanks. I'll take a look at that link in your sig.
    With the SWCG I'm not sure if I could get away with only 3-4 hrs. Right now I have it set to 70% to maintain CL, though it is an older cell (in it's 7th season) which may explain the higher setting. When the cell was new I only needed to set it to about 40% if I recall correctly.
    Which brings up a question. Is it better to run the SWCG at a lower setting (longer pump on time) giving the pool doses of CL throughout the day, or at 100% (shortest pump on time) dosing CL one time a day? (Lol, I've derailed my thread already!).
    mas985's Avatar
    Pleasanton, CA
    From the SWG perspective, 100% for 4 hours vs 50% for 8 hours is the same. From a FC perspective, it shouldn't matter either as long as the FC doesn't go below the minimum recommended FC level. So if you reduce pump run time and you know FC will dip some after the pump is off, then you just need to set the FC a little higher. However, with a SWG, you should have 60-80 ppm of CYA and so the FC should not drop that much when the pump is off.
    I run my pump 4 hours per day and the SWG output is set to about 95% specifically because I am trying to reduce run time as much as I can.
    Mark
    Virginia
    I appreciate you sharing your experience with this.
    I'm wondering how long my SWCG can stay off before CL dips below the minimum? I try not to let it dip below 5ppm with CYA maintained at 70-80ppm, and preferably maintain between 6-7ppm for a little wiggle room.
    Am I correct that if right now I have to set the SWCG to 70% for 12 hours, then running at 100% I would have to run it 8.4 hrs (12*.7=8.4)? Am I figuring that right?
    mas985's Avatar
    Pleasanton, CA
    Yes, that is correct. As for the FC, just measure it one evening after the sun goes down and see what it is. But at 8 hours, that should still be enough to cover most of the daylight hours anyway.
    Mark
