Years ago, I improvised an adapter to use a standard 1.25" corrugated pool hose as a vacuum hose on an Intex Easy-Set with a 3/4" PVC double female fitting (3/4" ID, not OD). I jammed it into the hose and it was the perfect fit into the Intex drain. You can probably do something similar.
