Closed Thread
Results 1 to 3 of 3
Thread: low alkalinity
    angiedubberke is offline Commercial pool users, operators, owners angiedubberke 0
    Aug 2014
    Wisconsin
    Default low alkalinity
    Ok...so I have a 2500 splash pad (slide, water features). For the last couple weeks I can't keep my alkalinity up. I am continually adding alkalinity increaser & hours later it is at a 50. Combined Chlorine is .2, ph staying at a 7.4, calcium is 200, Acid is 30...please help!
    BigDave's Avatar
    Jul 2010
    New Jersey
    Default Re: low alkalinity
    It's predictable that with constant aeration you'll lose alkalinity as carbon dioxide leaves the system. You might be able to slow it down a bit by letting the pH rise up to 7.8 or so.
    12'x24' oval 7.7K gal AG vinyl pool; ; Hayward S270T sand filter; Hayward EcoStar SP3400VSP pump; hrs; K-2006; PF:16
Closed Thread
  1. Alkalinity stuck at 0...after 50 lbs. Alkalinity Increaser
    By heyaim in forum Dealing with Alkalinity and Calcium
    Last Post: 07-22-2012, 07:51 PM
  2. Alkalinity
    By bobgard in forum Dealing with Alkalinity and Calcium
    Last Post: 08-09-2011, 02:28 PM
  3. low Alkalinity
    By lynn2_cal in forum Pool Chemicals & Pool Water Problems
    Last Post: 03-16-2007, 05:53 PM
  4. alkalinity at 320!?!?!?
    By gordyjamz in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-30-2006, 02:11 PM
  5. Total Alkalinity and Adjusted Total Alkalinity
    By cheshamjim in forum Dealing with Alkalinity and Calcium
    Last Post: 06-18-2006, 09:36 PM
