Thread: The Use of Chlorinator pucks
    BigDave's Avatar
    Default Re: The Use of Chlorinator pucks
    I looked at your other thread. You can't tell how much CYA you have from a test strip. The strip test for CYA is not reliable. That said, I wouldn't add any trichlor pucks to the chorinator until you get the K-2006 and find the pool's CYA level.
    ( oops...accidentally edited BD's post instead of mine...deleted it...sorry)
    If you cannot get the K-2006 you can get the HTH 6-way drop test kit at Walmart. its CYA test is the same as the K2006's
    Some stores even sell a stand-alone black dot CYA test kit that works on the same principle with the same reagent.
