Results 1 to 10 of 155
Thread: Test results on new pool in Tucson
Threaded View
  1. #27
    Sep 2014
    Tucson, AZ
    Default Re: Test results on new pool in Tucson
    Quote Originally Posted by Wilco View Post
    Looks like they will come to Tucson for $75 fee. Very nice guy contacted me back. Thanks, might tie it in with draining the pool a bit which they need to do anyway.
    Cool. Let me know how it goes, I was thinking about buying my own salt blasting equipment to do the job but if they do good work for you, that would be good to know. My scaling isn't too bad but I wanted to do the job over the winter.
    This statement is not necessarily true. Some pools lose all of their CYA over the winter. We see it all the time. When this happens (CYA biodegrades), you are often left with ammonia in the water as a byproduct and a huge chlorine demand upon opening. No way to tell which pools this will happen to, unfortunately.
    Thanks @Watermom! I was going to add that into my statement but did not want to get into the weeds about it. I think the CYA-Ammonia conversion only happens in pools that are "closed" over winter. In those pools, the low-level algae that forms (after all the chlorine and polyquat is gone) then converts the CYA into ammonia. I have not heard of that happening in a pool that is run all year round like we do here in the Southwest because, presumably, we hope to have no algae in our pools to do the conversion but I would be interested in hearing about cases where CYA was consumed by some other chemical mechanism. I guess if a pool was allowed to turn into a green swamp, then the algae would consume all the CYA and produce ammonia, but that would be the extreme case of someone just neglecting their pool.....Hey! Maybe that's the solution to excessive CYA!?!?! Let your pool turn into a swamp for a while until your CYA levels go to normal
    joking!!
