Results 1 to 9 of 9
Thread: Is bubble need during the winter for above ground
    rdefino is offline Registered+ Thread Analyst rdefino 0
    Jun 2013
    Haverhill, MA
    Default Is bubble need during the winter for above ground
    I live in Mass, and we get snow and low freezing temps.
    I was told a cover is not needed, but can help with not having an algae bloom in the spring.
    But is a bubble needed for an above ground during the winters if the top few inches might freeze?
    thanks
    Oval 18x34 14400 Above Ground Dough Boy, DE Pentair
    Default Re: Is bubble need during the winter for above ground
    If you use a cover, you must use a pillow of some sort to support the cover and, hopefully, have water flow off it. The water/ice in the pool acts as a support because otherwise the ice, snow and water in the cover puts a ton of inward pressure on the pool walls and can bend and collapse them. The ice on the top of the pool water is no big deal. In fact, if you keep your pool open the ice will keep debris from going to the bottom.
    Watermom does not cover her AG pool over the winter. Other AG pool owners don't either. My dad used to use 6 or 8 truck inner tubes as his "bubble" and they worked great.
    So the job of the pillow is to support the cover against ice and snow.
    BigDave's Avatar
    I find the pillow also helps pumping the water off the cover because it keeps it near the edges and easier to reach.
    Jun 2013
    Haverhill, MA
    Thanks for the replies.
    Now would I have to worry about the sun fading my liner with no cover?
    In the winter? In Massachusetts????
    I never have a problem.
