Results 1 to 9 of 9
Thread: Is bubble need during the winter for above ground
    rdefino is offline Registered+ Thread Analyst rdefino 0
    Jun 2013
    Haverhill, MA
    Default Is bubble need during the winter for above ground
    I live in Mass, and we get snow and low freezing temps.
    I was told a cover is not needed, but can help with not having an algae bloom in the spring.
    But is a bubble needed for an above ground during the winters if the top few inches might freeze?
    thanks
    Oval 18x34 14400 Above Ground Dough Boy, DE Pentair
    Default Re: Is bubble need during the winter for above ground
    If you use a cover, you must use a pillow of some sort to support the cover and, hopefully, have water flow off it. The water/ice in the pool acts as a support because otherwise the ice, snow and water in the cover puts a ton of inward pressure on the pool walls and can bend and collapse them. The ice on the top of the pool water is no big deal. In fact, if you keep your pool open the ice will keep debris from going to the bottom.
    Watermom does not cover her AG pool over the winter. Other AG pool owners don't either. My dad used to use 6 or 8 truck inner tubes as his "bubble" and they worked great.
    So the job of the pillow is to support the cover against ice and snow.
    BigDave's Avatar
    I find the pillow also helps pumping the water off the cover because it keeps it near the edges and easier to reach.
    Jun 2013
    Haverhill, MA
    Thanks for the replies.
    Now would I have to worry about the sun fading my liner with no cover?
    In the winter? In Massachusetts????
    I never have a problem.
    Jun 2013
    Haverhill, MA
    Thank you. Odd, growing up I was always told a bubble was need to keep the ice from pressing on the inside of the walls of the pool. It gave the ice the ability to push into the bubble being that the bubble is flexible. Any truth to that?
    BigDave's Avatar
    I always thought that as well and it may have been true then. Modern AG pool walls are usually formed in a slight zig-zag pattern that's supposed to accomodate the expansion of the ice.
    Jun 2013
    Haverhill, MA
    mmm, is that why my doughboy when looking at the wall from above it's in a wave pattern. the side go in and out.
  1. Above ground pool almost empty after winter
    By MHouse in forum Above-Ground Pool Construction & Repair
    Last Post: 04-01-2014, 12:49 PM
  2. How to re-level an above-ground pool after winter damage
    By Gr8dane in forum Above-Ground Pool Construction & Repair
    Last Post: 03-23-2014, 11:32 PM
  3. To Bubble or not to Bubble that is the question....
    By robbym70 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 11-15-2011, 09:03 PM
  4. Mesh winter covers for above ground pools?
    By Nectarologist in forum Pool Equipment & Operations
    Last Post: 08-23-2011, 10:26 AM
  5. What to look for in an above ground winter cover?
    By gonefishin in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-15-2006, 10:49 AM
