Results 1 to 10 of 34
Thread: The Green Pool
    Aug 2014
    Florida
    Default The Green Pool
    Our pool was only green when the sun hit is, otherwise it looked black. Came that way with the house so about 5 months with no maintenance.
    About 4 days in and the water is cloudy but almost no green left or tadpoles.
    CL - 30
    CYA - 100
    TA - 120
    PH - 7.2
    Ch - 100
    IG Plaster, 10550 gallons no questions yet thing a progressing as expected although slower than I would like. Using bleach, borax, and baking soda. Taylor 2006 test kit. CC 75 filter.
    Just an FYI of were it was when we started.
    CL - 0
    CC - 0
    TA - 30
    PH - to low for the test kit
    CH - 100
    Did I mention it was dark dark green, and full of tadpoles.
    BigDave's Avatar
    Default Re: The Green Pool
    Sounds like you've been doing your homework - Awesome!
    You will need to get some more calcium to protect what's left of the plaster. You could try using calcium hypochlorite for chlorine for a while. Every 5lbs of 53% cal-hypo (don't use lower - no copper or multi-action) will add 3ppm FC and about 2ppm CH to your pool. Might be a good idea to push the pH up to about 7.5 as well.
    The most important thing right now,as you know, is the chlorine.
    Depending on where you are, you may be able to get calcium hypchlorite that's above 60%. If you can, (I THINK Pool Life sells it) use it. As BigDave says, you need to get your calcium level up to at least 200ppm.
    Aug 2014
    Florida
    Oh my I found the bottom of the pool today. Water results:
    My results Pool store results:
    CL - 10 steady CL - 5
    FC - 10 FC - 5
    CC - 0 CC - 0
    PH - 7.4 PH - 7.4
    TA - 120 TA - 110
    CH - Not sure CH - 225
    CYA - 100 CYA - 100
    CH is the only thing I am concerned with they have come up with 200 - 200 - 225 for the last 3 days I am reading lower. I have a taylor 2005 not a 2006 bought the wrong one. Could the high clorine level over the last few days have been skewing my results?
    Before: https://flic.kr/p/oJTBA6
    After: https://flic.kr/p/p2nJZF
    Aug 2014
    Florida
    I am in Florida I have not been able to find it here yet. Except at the pool store of course. They tell me I am good but my readings are low. Decided to focus on getting it clear and stable and see what kind of CH I get.
    Aug 2014
    Florida
    Now that I can see it the plaster looks to be in good shape and feels smooth were I can get to it, keeping my fingers crossed that is the case through out the pool.
    Yes my biggest concerns so far have been chlorine, ph and alk. Added roughly another pound of borax after those test result to bring the ph up just a bit more.
    If your CYA is 100 and your pool is full of algae, you need to increase your FC to at least 25ppm to kill the algae.
    Aug 2014
    Florida
    Algae is dead Carl not a spot of green anywhere.
    Good! Then you can go on to filtering/vacuuming the dead algae out, and balancing your chemistry.
