Results 1 to 10 of 34
Thread: The Green Pool
    Default Re: The Green Pool
    Regarding moderation --- you have to supply verifiable information when you register to not require posts to go through moderation. Another avenue is to become a subscriber. Subscriber posts do not go through moderation and we also have a separate section of the forum for our subscribers to post their questions in so that they will get priority attention.
    About the OTO and DPD-FAS kits ----- the OTO is very reliable but not super accurate. It will only read chlorine levels up to 5ppm. The FAS-DPD kit allows you to read chlorine readings up to around 50ppm which becomes important if you need to shock the pool or if you have a high CYA pool which requires you to run higher than normal chlorine readings.
    Hope this clarifies these things for you.
    Aug 2014
    Florida
    I updated my profile.
    Reliable but not accurate not sure how it can be both. My question was why would you need both? Seems the FAS-DPD kit is the way to go.
