Re: Using 1-25 Micron Bags in Skimmer
I have read a bit on that site. And I do test regularly, albeit with a cheaper test.
This may be a dumb question, but when should I shock, when should I vacuum, and at what level should I keep the chlorine while the filter is constantly getting clogged?
I do not feel able to vacuum the pool without getting in it. So, it seems like I have to do one or the other but can't do both.
