Closed Thread
Thread: alternatives to chlorine/non-chlorine pool maint
    Default alternatives to chlorine/non-chlorine pool maint
    hello to all, looking at uv and copper/silver ion systems coppper/titainium oxidation systems. we all know that chlorine isn't good for us, so i'm looking at other systems. any thoughts?
    Exclamation
    Chlorine is probably the safest and most effective sanitizer there is with bromine being good for certain situations like spas and indoor pools. UV only sterilizes the water in the reaction tube...there is no residual. I have used uv in fishtanks for many years so I am familiar with it. Ditto for ozone, which is very poisonous! Metals (call them ions or oxidation systmes if you like) ARE chemicals and have their own danger. They still require a residual stanitizer, usuallly chlorine but at a lower dosage than if used alone. You might want to read Ben's FAQ on metals in the forum and the info he has on the sister website hppt://www.poolsolutions.com. I think it will change your mind about using chlorine vs. alternative sanitation!
    duraleigh Guest
    Default
    Quote Originally Posted by leewest
    Hi, Lee,
    Chlorine not good for us???? Well, imho, the alternatives are worse....much worse. Copper? Silver?...No thanks. UV? Yeah but then how do you kill the bugs in your pool since there is no residual.
    Too much Cl will certainly kill you....So will too much mashed potatoes if you really consume "too much"!!!
    Correctly used, there are many things in our daily lives that are quite beneficial as long as we don't decide to get stupid and make them lethal.
    Default Thread has been moved by moderator
    I have moved this thread to the Stains & Metal Matters: Iron, Copper, Silver & More forum. Please add any further replies there.
    Thank you.
    Watermom
Closed Thread
  1. Chlorine tabs vs chlorine bleach generic
    By Cahoonh in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-13-2013, 10:28 AM
  2. Looking for chlorine alternatives . . .
    By ChristinaLucia in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-05-2012, 05:17 AM
  3. High Chlorine Level with no Chlorine Added in 6 weeks
    By morechoff in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-27-2006, 08:52 AM
  4. Free Chlorine vs. Total Chlorine adjusting
    By Truckman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-08-2006, 06:00 PM
  5. Pool Start Up & Maint
    By tysmom in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-07-2006, 09:27 PM
