Results 1 to 10 of 16
Thread: How Much Can a Liner Fade?
    Default Re: How Much Can a Liner Fade?
    Some of it, is, of course, 12 summers in the sun. It's quite possible, as Ben has discussed the extreme variability of vinyl quality, that this vinyl was less impervious to UV rays. The floor of the liner faded far more than that walls of it (you can only see a little on the right of the picture) which leads me to believe UV more then FC faded it. That wall portion you see is on the South side of the pool, so always a little more shaded as it looks North. Some is due to my preferring to kill a bloom fast, so we can swim faster, such as when we came home from a month away to a green pool, knowing I was planning to change out the walls and liner, I simply hammered the FC (and replaced the coffee maker! )
    I suspect that over a decade most liners fade and fade a lot, but if you don't have a reference point, as I do, you only sort of notice it.
    Virginia
    Our liner has faded below the water line since 2004. It's only noticeable if the water level is below normal and you look at the border pattern.
    Since the fading is below the water line I assume it's from exposure to chlorine all these years.
    Jul 2013
    Northern Illinois
    Liner reference comparison.... Kinda reminds me of how I feel when I look at my wedding pictures and then look at my hubby. Who IS that old (faded) fart, anyway? How did THAT happen???
    Funny, the liner doesn't bother me, the mirror does. But I sometimes think my wife has her own "Dorian Gray" portrait.
    "The way she sees and the way he looks they're a poifect match!"--Classic line from "A Fiddler On The Roof"
    Jul 2013
    Northern Illinois
    "Poifect" hahahaha!
    Jul 2014
    MA
    That liner fading looks similar to the look of the liner I replaced last year. It is probably caused by a combination of UV and chemicals.
    My last liner was an overlap liner. The area covered by the coping was still the original color when I removed the coping. The top foot of the liner faded different depending on which side of the pool you looked at.
    How "brittle " is the vinyl on the floor of the pool?
    FantaSea AG pool, 16' x 32' x 4' flat bottom, Hayward T210 sand filter
    Since there was a different pattern at the top of the liner, you didn't see fading there. I suspect some was due to my Blue Diamond robotic.
    The vinyl all over doesn't seem particularly brittle. Perhaps being dry and in the air may change that.
