Liner reference comparison.... Kinda reminds me of how I feel when I look at my wedding pictures and then look at my hubby. Who IS that old (faded) fart, anyway? How did THAT happen???![]()
Funny, the liner doesn't bother me, the mirror does. But I sometimes think my wife has her own "Dorian Gray" portrait.
"The way she sees and the way he looks they're a poifect match!"--Classic line from "A Fiddler On The Roof"
"Poifect" hahahaha!
That liner fading looks similar to the look of the liner I replaced last year. It is probably caused by a combination of UV and chemicals.
My last liner was an overlap liner. The area covered by the coping was still the original color when I removed the coping. The top foot of the liner faded different depending on which side of the pool you looked at.
How "brittle " is the vinyl on the floor of the pool?
FantaSea AG pool, 16' x 32' x 4' flat bottom, Hayward T210 sand filter
Since there was a different pattern at the top of the liner, you didn't see fading there. I suspect some was due to my Blue Diamond robotic.
The vinyl all over doesn't seem particularly brittle. Perhaps being dry and in the air may change that.
I had my liner exposed to the sun for about 2 months during my rebuild, so near the end it was pretty brittle relative to new vinyl. More a stiff feeling than brittle, but easy to puncture as compared with new vinyl. The old liner was great protection for the sand during the rebuild.
I never had to patch that 2nd liner over 14 years of use, so I made out pretty well. The original liner was installed poorly, and needed mutiple patching.
I am still running low chlorine (around 1.0) along with Nature 2 with the new liner. Trichor in an auto chlorinate dispenser. One chlorine fill of 8 to 10 of the 3" tablets about 4 weeks apart. Once a month "super" chlorination, but not as "super" this time. I use a 1/2 a gallon of liquid chlorine to super chlorinate. PH plus every once and a while (depending on "acid rain" amounts). A small amount of algaecide once a month.
This time I am being very careful about "super" chlorination levels.
This year I also installed new sand and replaced the internals to the Hayward sand filter. Plastic gets brittle over the years.
Zero algae this year. Then again, it was kind of a cold summer this year.
I've noticed that NOW the bottom is getting brittle, but, like you, I'm leaving it in place as a tarp over the sand.
On the chemical side, I'd never use a Nature2 because, while it helps control algae, it adds metals. While it's expensive, an SWCG will allow you to do the same thing.
Are you careful to watch your CYA levels with the Tri-Chlor? Remember for every 10ppm of chlorine it adds 6ppm of CYA.
My sand filter is fine and the plastic tank shows no sign of brittleness or UV breakdown. It's always been covered over the winter, and, for the last several years, been under the deck addition (where the deck chairs are). I'm still using my original sand, no problems.
