Results 1 to 10 of 13
Thread: Got the pool up, beaded liner installed, wrinkles out of the floor, filling and...
    Jul 2014
    MA
    Default Re: Got the pool up, beaded liner installed, wrinkles out of the floor, filling and..
    Pictures are always good so we can see what you mean.
    Are you sure that the liner being used was designed to use with the cove installed? My pool liner was sized to be used with no bottom cove.
    Just wondering why you installed the drains on the bottom of the pool? My drain is installed on the wall of the pool. The bottom drain sure makes life complicated.
    FantaSea AG pool, 16' x 32' x 4' flat bottom, Hayward T210 sand filter
    DennisP is offline Registered+ Thread Analyst DennisP 0
    Jul 2014
    New Berlin, WI
    Actually, the main drains were not a big deal at all... I was a bit nervous about the foam funneling correctly to the drains, as I installed the drains to about half the depth of the foam bottom to achieve that effect. In the end it worked exactly as I expected it to and the main drains are golden. Even setting them with concrete and everything else associated was a non-issue in the end.
    About the only thing the main drains do is not allow me to adjust the liner once the holes for them are cut. But I was concerned about the water pressure pushing the liner into the drain holes too agressively, thus causing wrinkles if I filled it too far before cutting them in... So I waited until the water was about 4-5" deep and then mounted the trim rings, cut out the centers and put the covers on.
    As I am filling already today I am noticing the liner on the walls looking good 70-80% around the pool, the one side that has the seam an extra inch or so up the cove compared to the other side is the "problem area". If I can get it set smooth everywhere but there I may just have to live with it folded a bit near the bottom, if that is even doable without totally messing it up. I would just hate to have to fill, then drain, then fill again to get this all figured out.
    I have three hoses going into the pool to fill it up at the moment. There is still plenty of water pressure in the house, so I may just get a faucet adapter and use the mudroom sinks faucet to aid it even more...
    I hope everything works out, just that it seems like everything about this project has been "against me" in regards to time and things going right the first time without having to constantly rework things. For me that is a big deal since I am meticulous about designing/engineering/planning and execution so that stuff usually just "falls into place". And some of the stuff has, just that a bunch of stuff has just been a major PITA.
    Jul 2014
    New Berlin, WI
    As a side note, should I have filled the pool overnight instead of during the day?
    I know people say to fill while the sun is out to help it make the liner soft and stretchy, but in my case is that a bad thing?
    I was just concerned with there being too much tension on the sides that seem to have "too little" material and them pulling from the bead receiver at those locations.
    I am getting sun on 3/4s+ of the pool. One of the "short" sides is in shade and I can't do much about that, but the rest of the liner is all in the sunlight.
    Jul 2014
    New Berlin, WI
    Ok, it has about a foot and a half (maybe a little more) of water in it. Pics of the "offending" areas:
    The seam is at the bottom of the cove, to about 3/4" away from the cove at worst on the shorter sides. On the long ends it is smack dab in the middle of the cove on one end and on the other end it is at the top of the cove.
    So, do I continue to let it fill and see how bad it is when it is done?
    Or, do I get in with it partially full and pull down on the "long ends" and pull the "extra" material down to the cove area if possible?
    I would rather not let it totally fill to just have to drain it to accomplish that.
    Oh, I also did not use a shop vac to suck the air out behind the liner. Like I mentioned I have it set pretty darn well already and expected it to just tighten up, but I don't think it is possible on the "long ends"... What sucks is about 15-20 degrees away from the worst area on both ends I have the skimmer/return on the better of the two ends, and the worst of the two has a single return. Am I correct that if I don't get those areas tight it will just be a nightmare to get those in without issues now or in the future? That is why I was thinking of just pull the extra material down to near the cove if possible to allow it to get tight up top.
    Jul 2014
    MA
    I installed a rectangular liner last year, and I had to rework it a bit to get the side seams even all the way around and all of the corners in the corner.
    I used the vacuum method to get out most of the air out from behind the liner, then did a shallow water fill. I did have to drain the pool down to even out the side seams so they were plus or minus one inch.
    After I got the liner in the final position and all the floor wrinkles out of the bottom, I filled to about 6 inches and cut in the lower side wall drain. I then filled the pool and adjusted the liner and coping connections as needed (off by a bit in the corners). The last thing I did when everything was straight was to cut in the upper return connector and skimmer.
    Is your skimmer and return outlet cut into the liner yet?
    Anyhow, I would probably drain and rework the liner a bit if at all possible to get the sidewall seams close to even (but not perfect).
    Jul 2014
    New Berlin, WI
    Well I contacted the vendor I purchased the pool liner from and sent them the pics they needed. It is obvious that there is about 3 inches extra material on the one side and there is 2 extra inches on the other side. It continues in an arc around both sides and tapers off to where it is basically perfect.
    I am waiting to hear back from them, so hopefully they can do something here. Their website states all liners are made in North America from virgin vinyl, yet the box I received said it was made in China and had a Chinese QC sticker on the front and back sides of the liner itself.
    I am hoping something can be worked out, but it is obvious that the liner is defectively manufactured.
    For the meantime I was going to be damned if my kids aren't going to have at least a few dips in the pool this year, so I ended up pulling the liner down mid-way to tighten up the top section, got the returns and skimmer cut in, finished off the piping and fired up the pump and heater...
    I need to refresh on the chemical startup stuff for a full size pool and will probably get a few socks with CYA hung tonight as well as some chlorine added. I will pickup a HTH 6-way test kit tomorrow on the quick and order a proper test kit for next spring. We have darn near perfect water out of the tap here, so I have very little adjustments to make outside of adding chlorine and CYA.
    I still need to get the upper rails and upper covers and lower cuffs mounted, but the kids should be able to swim tomorrow for a bit. Since their entire summer was "stolen" by delays in the pool and patio project, it is the least I can do to bust my hump getting things "usable" for them. The kids understand, but the guilt was just killing me. They all try really hard at everything (a few of them have autistic spectrum disorders) and I just want them to have some sort of "highlight" as a bright point for this summer.
    Jul 2014
    New Berlin, WI
    Well, for tonight, I added a gallon of 12.5% liquid chlorine and hung a sock with 24oz of cyanuric acid from the ladder... I figure that should be good until the morning when I will get a test kit and check it out...
    I will say, there is quite a nice rotating current with two returns in the pool... Outside of the liner issue, it is really nice to see it up and running... Lots and lots of work involved in doing it this way with all the hardline plumbing...
    But, the killer part is I found out that I was perfectly level all around the site. When the water came up to the skimmer it touched the lower edge of the faceplate all across it at exactly the same time. Same with the bottom edge of both returns.
    Jul 2014
    New Berlin, WI
    Well, a followup after a week or so...
    The family has used the pool 3 or 4 times... I started using the solar cover, BIG difference in keeping heat in...
    I also have found that chlorine usage isn't great at all... I have a 35ppm or so CYA level and I usually end up adding maybe a half gallon of 12.5% liquid chlorine every 2-3 days... And that is with the pool temp at 83-87 degrees or so...
    Also I ended up burying the second return line and adding unions to the line since it made adding the pavers around the pool easier... Look much better like that anyways...
    I have not heard back from the liner people (surprise), so I will give them a call tomorrow...
    Overall, outside of the liner issue, I am pretty happy with how it turned out... The foam bottom is perfect (everyone raves about it) and the foam walls are a nice touch as well. The Morada 6 RTR pool is very nice looking fully assembled and the upper resin rails have a great design that keeps water from being splashed out of the pool from the inside. With my paver ring design it is perfect as there is no way the kids are going to get water on the exposed 8" area just beyond the pool. All water splashed out will hit the pavers or beyond, so I have no concerns with too much water getting into the substrate under the pool. Actually, when I fill that space with pink/black rocks (like the rest of the landscaping has) I might just go with a finer stone mounded higher before the bigger stone to even further increase the "watershed" from that gap.
    Hmm, I might even be able to figure out some sort of angled "splash guard" that would divert all the water to the pavers, and just put a smaller layer of larger stone on top of there... That way there would be minimal water infiltration.
